Calculating Impedance Using Capacitive Reactance
11 replies · 5K views
PeachBanana
A 29kΩ resistor is in series with a 62mH inductor and an ac source. Calculate the impedance of the circuit if the source frequency is 80Hz .
XL = ωL
Z = [(R^2 + (XL - XC)^2)] ^ 1/2
R = 29,000 Ω
XL = 0.062 H (2∏ * 80 Hz)
XL = 31.16 Ω
I'm having difficulty figuring out how to find XC. XC = 1 / ωC but what is "C?"
XL = ωL
R = 29,000 Ω
XL = 31.16 Ω
Your formula for Z applies to RLC circuits. You have an RL circuit. Do you know how that formula for Z was derived? It was probably using a phasor diagram. If you understand the derivation, it's pretty easy to see what you need to do.
Was the formula for "Z" derived using the Pythagorean theorem? If so, I still do not see the connection to capacitance.
Describe how the formula was derived.
It looks as if it uses the following relations:
Vrms = Irms * Z
Vnaught = InaughtZ
The book also shows a phasor diagram where Vnaught is the sum vector and acts as the hypotenuse of the triangle.
And where does the triangle come from?
The triangle comes from a phasor diagram. I'm attaching an image made in paint of the one I see in the textbook. It's a tad messy, but it is readable.
In your picture, I should actually point in the same direction as VR=IR.
Do you understand why the one leg is VL-VC and why you add all the voltages?
Are the voltages being added together to find the peak voltage source, Vnaught?
Is Vc subtracted from Vl because Vc lags the current by 90°?
Yes, it's Kirchoff's voltage law applied to the elements in series.
And because VL leads the current by 90°. The two phasors point in opposite directions, so when you add them vector-wise, you subtract their magnitudes.
So back to your original problem, if you follow the same analysis, what do you get for the impedance?
Since this is an RL circuit then
Z = [(R^2 + XL^2)]^1/2
Yup, you have it.
