Calculating Radiation Measured from Moving Star
  • Level: Graduate
  • Thread starter asras
    Radiation Star
4 replies · 2K views · last reply
asras
My problem is how to calculate the radiation measured from a moving star. I figure there's two ways to do it, both of which I go through below, but they do not produce the same answer!
For the first part everything is in the rest frame, [itex]\mathcal{O}[/itex], of the star.
The star emits [itex]N[/itex] photons of frequency [itex]\nu[/itex] each second. The total energy radiated per second is thus [itex]L := Nh\nu[/itex]. It can be shown the stress-energy tensor in this case has entries for events [itex](t,x,0,0)[/itex]:
[tex]T^{00} = T^{0x} = T^{x0} = T^{xx} = \frac{L}{4\pi x^2},[/tex]
and all other entries zero.
We now move to the frame of the observer, [itex]\overline{\mathcal{O}}[/itex], who moves with speed [itex]v[/itex] in the positive [itex]x[/itex]-direction and who is also located on the x-axis. The components of the stress-energy tensor in this frame are given by (using the usual rules for tensor transformation):
[tex]T^{\overline{\alpha} \overline{\beta} } = \Lambda^{\overline{\alpha}}_{\mu} \Lambda^{\overline{\beta}}_{\nu} T^{\mu \nu}[/tex]
Now if the coordinate of reception is [itex]x[/itex] in the star's frame it must be [itex]R = (1-v)\gamma x[/itex] in the observer's frame (with [itex]\gamma = (1-v^2)^{-1/2}[/itex]). Thus we have that
[tex]T^{\overline{0} \overline{x}} = \frac{L}{4\pi x^2} (1-v)^2 \gamma^2,[/tex]
[tex]T^{\overline{0} \overline{x}} = \frac{L}{4\pi R^2} (1-v)^4 \gamma^4.[/tex]
So this gives the radiation the observer measures. However if we approach the problem using doppler-shift of the photons we get [itex]\nu' = (1-v)\gamma \nu[/itex], [itex]R = (1-v)\gamma x[/itex], and we have
[tex]T^{\overline{0} \overline{x}}= \frac{Nh\nu}{4\pi R^2} (1-v)^3 \gamma^3.[/tex]
So which is correct? I'm fairly sure the first method is correct, but I can't figure out exactly what I'm missing in the second calculation.
In the second method, you transformed x, did you forget to transform t as well? N, the "number of photons per second", will change.
Bill, wouldn't that just be equivalent to
[tex]N \rightarrow N/\gamma,[/tex]
due to time dilation? (If it were [itex]N \rightarrow N/((1+v)\gamma)[/itex] I would be happy!)
It's not just time dilation. Like you say it's γ(1 + v/c), the same as the Doppler shift factor. It's the number of photons you're intercepting per second. One way to see the need for the (1 + v/c) factor is that N will be different depending on whether the star is moving toward you or away from you, which changes the sign of v.
Ah, I see. If we imagine two emission events (lets just say that one photon is emitted at each event) separated in the rest frame of the star by [itex]\Delta \tau[/itex] the rate of emission is [itex]L = 1/\Delta \tau[/itex]. In the frame of the observer the events are separated in time by
[tex]\Delta t = \Delta \tau \gamma.[/tex]
However the star has moved [itex]v\Delta t[/itex] to the left so the rate of emission in the observers frame becomes
[tex]L' = \frac{1}{\Delta t + v\Delta t /c } = \frac{1}{\Delta \tau} \frac{1}{(1+v/c) \gamma} = \frac{L}{(1+v/c)\gamma}.[/tex]
(I included the c because I feel it makes it clearer.)
Thanks!
