Calculus involving accln and vel
  • Thread starter sidrox
    Calculus
9 replies · 3K views · last reply
sidrox
A point moves rectilinearly with a deceleration whose modulus depends on the velocity v of the particle as
a=(alpha) X (square root of velocity v),​
where alpha is a positive constant. At time t=0, the particle has initial velocity v1.
Then, what are the following:
i. Time taken by the particle to come to rest
ii. The distance traveled before it stops
iii. The time at which the instantaneous velocity is (v1)/4
iv. Distance traveled at the time the velocity becomes (v1)/4.
I tried to integrate the equation but ended up no where because of the v term in the given equation, which kept getting in my way...PLEASE HELP!
I want to learn how to solve such problems which involve such variables in their equations...
Writing x' and x" for dx/dt and d^2/dt^2 (Latex takes too long!)
Your equation is x" = ax'^2
The "trick" for solving this is to substitute y = (1/2)x'^2
y' = x'x"
x" = y'/x' = (dy/dt) / (dx/dt) = dy/dx
So the equation becomes dy/dx = 2ay.
No, the equation is NOT x"= ax'^2: it is x"= -a sqrt(x').
(negative a (or alpha) because you are told that the deceleration is given by alpha sqrt(v) where alpha is a positive number.)
I would have done it just slightly differently. Your base equation is
[tex]\frac{dv}{dt}= -\alpha \sqrt{v}= \alpha v^{\frac{1}{2}}[/tex]
That's a "separable" equation- you can write it as
[tex]v^{-\frac{1}{2}}dv= -\alpha dt[/itex]<br /> <br /> That should be easy to integrate. Once you have solved for v(t), of course<br /> [tex]v= \frac{dx}{dt}[/tex]<br /> so you have a second integration for x(t).[/tex]
[tex] <br /> Hmmm...i got the idea...<br /> but my problem now is how to apply the limits...on integrating, what i got was:<br /> <br /> [tex]2 \sqrt{v} = \alpha t[/tex] <br /> <br /> <i hope the latex is right, i am using it for the first time!<br /> <br /> now for the above equation, what will my limits be and where do i bring in the v1 term?[/tex]
Progress!
[tex]- \alpha \sqrt{v(t)}= \frac {dv}{dt}[/tex]
[tex]- \alpha t = 2 \sqrt{v(t)} + 2\sqrt{v(0)}[/tex]
[tex]- \alpha t = \{2 \sqrt{v(0)}[/tex]
The above is because the velocity is 0 (in the first sub division of the question)
and thus,
[tex]t = \frac {2 \sqrt{v(0)}}{\alpha}[/tex]
Now how do i proceed?
Yes, [itex]t = \frac {2 \sqrt{v(0)}}{\alpha}[/itex] is the time until the particle comes to rest (v= 0).
Now, since you know that [itex]- \alpha t = 2 \sqrt{v(t)} + 2\sqrt{v(0)}[/itex] you can solve that equation for v(t): [itex]2\sqrt{v(t)}= -2\sqrt{v(0)}- \alpha t[/itex] so [itex]\frac{dx}{dt}= v= (-\sqrt{v(0)}-\frac{\alpha}{2}t)^2[/itex].
is this true??
[tex]\frac{d}{dt} \-v(0) = 0[/tex]?
is that right?
okay...here is my working:
[tex]2 \sqrt{v} = - 2\sqrt{v(0)} - \frac {\alpha t}{2}[/tex]
On squaring,
[tex]v = v(0) + \frac {\alpha^2 t^2}{4} + \sqrt{v(0)}\alpha t[/tex]
On writing v as [tex]\frac {dx}{dt}[/tex], and then integrating:
[tex]x = 0 + \frac {\alpha^2 t^3}{12} + \frac { \sqrt{v(0)} \alpha t^2}{2}[/tex]
and i am going to continue in a separate post becos i am new to laTex and i hope all that i have typed isn't a mess...:rolleyes:
Now the body comes to rest at
Thus, i substituted the above expression for 't' in the expression for 'x'.
and i have gotten the following value for x, but it is not one of the options.
i got:
[tex]x = \frac {8 \sqrt{v(0)}^3}{3 \alpha}[/tex]
Where am I going wrong?
You were NOT told that the initial velocity was 0! You were told
You have determined that
[tex]2\sqrt{v(t)}= -\alpha t+ C[/tex]
Taking t= 0 [itex]2\sqrt{v1}= C[/itex]. That gives
[tex]2\sqrt{v(t)}= 2\sqrt{v1}- \alpha t[/tex]
squaring that equation,
[tex]4 v(t)= 4 v1- 4\sqrt{v1}\alpha t+ \alpha^2 t^2[/itex]<br /> <br /> The particle will "come to rest" when that is equal to 0.<br /> <br /> Now you have<br /> [tex]v(t)= \frac{dx}{dt}= v1- \sqrt{v1}\alpha t+ \frac{\alpha^2}{4} t^2[/itex]<br /> <br /> That should be easy to integrate for x(t).[/tex][/tex]
