Calculus: Limits Homework - Find f'(x) & Why Wrong?
  • Thread starter Thread starter Ris Valdez
    Calculus Limits
6 replies · 2K views
Ris Valdez
Find f ' (x) if f(x) = 4x + 4 / x2 + 4
I used the mnemonic "lo dhi - hidlo / (lo)^2
I got -4x^2 +16-8x / (x^2+4)^2
but it's telling me I'm wrong? Why? I computed it again but I still got the same answer.
If you're doing calculus, you need to be able to write your expressions correctly. Please put brackets where they are required. It's impossible to know what expressions you are actually dealing with here.
Sorry!
Problem: find f ' (x) if f(x) = (4x + 4) / (x^2 + 4)
My answer (which was marked wrong by wiley): (-4x^2 + 16 - 8x) / [(x^2 + 4) ^2]
Is that good enough?
Ris Valdez said:
Sorry!
Your answer looks correct to me.
At first I got a different answer, it was because I didn't put brackets around the second term. It's quite easy to make that mistake, so I'll bet Wiley wanted the 8x to be positive (which wouldn't be correct).
Who is this "Wiley" person and how did he or she mark your answer incorrect? If you are using some "mechanical" scoring, those things are notorious for marking wrong anything that is not in exactly the form it wants.
The quotient rule is quite ugly to use in general (which is what you have used to find the answer).
It is actually much easier to re-write the expression as:
$$f(x) = \frac{4x + 4}{x^2 + 4} = (4x + 4)(x^2 + 4)^{-1}$$
This allows you to take advantage of the product and chain rules, and usually you will be able to find the derivatives of quotients much faster:
$$f(x) = \frac{4x + 4}{x^2 + 4} = (4x + 4)(x^2 + 4)^{-1} = (4)(x^2 + 4)^{-1} - (4x + 4)(x^2 + 4)^{-2}(2x)$$
