Can comets create a microclimate crater on Mars 30km deep with 0.7bars?
  • Thread starter Thread starter darkdave3000
    Comets Mars
47 replies · 8K views
darkdave3000
TL;DR Summary: Can comets either one or many create simultaneously overlapping impact craters for higher air pressures to breed algae and plant life as a micro climate?
Is there a depth limit to crater creation on a planet? Let’s say Mars for a depth of 30km can it be done? Assuming the projectile is an icy comet. And we have the option to use more than one at whatever time interval. Also sequential and simultaneous clusters are an option too and we can give each rock angular momentum(spin).
Scale height of Mars is 11.1km and according to my calculations from -7km elevation on Mars a -37km should yield 0.7bars. Since trees can survive on mountains with similar pressures and it’s within the Armstrong limit I am thinking a win win scenario if a planet killer was deflected from Earth and toward Mars as it will also carry water ice to the bottom of the new Martian crater as liquid water (it can stay liquid since there it’s below the Armstrong limit) for plant and algae life to breed if we so choose to plant them there. The water can also be rocket fuel and oxygen source after electrolysis in addition to drinking water. In this case soda since it will mix with CO2.
A comet such as Haileys would have sufficient ice by it self to increase Martian atmospheric material, pressure and density by 1%. While negligible with just a single comet: with repeated engineered crashes up to a hundred we could double the Martian atmospheric density and pressures gradually reducing the required depth(by half from -30km to -15km ) of future micro climate semi habitable craters to terraform Martian atmosphere slowly with photosynthesis from CO2 to O2.
Yes there is. And 30 km surely cannot be done.
Look at Hellas basin. Large impact basins on Moon, Mars et cetera do not get deeper.
The reason is the strength of rock. The rock shattered and softened by impact simply flows back and refills the basin to a roughly flat floor, with waves (single central peak or several rings).
What can be done then? You say the rock shattered and softened flows back and refils the basin to rouhly flat floor. But how much of a percentage does it refil from the initial pre strike elevation? 100%? Or 90%? How do I calculate how much I can excavate each time I smash the same spot with a comet? If maximum has already been reached at Hellas because it's the bottom of a crater what about another similar elevation spot that is not part of a crater such as the Northern Lowlands? How do I confirmed mathematically that the lowest point has already been reached and that there's no more useful depth to extract for a planet? Can I cheat with cluster strikes? Can I splash up molten material into space with a 2nd comet seconds after impact of the first to excavate deeper? What would you do if aliens put a ray gun to your head or family and said u gotta figure out a way to do this or else?
Because the comet is ice and the planet is rock, you stand a snowflake's chance in Hell of making a deep hole with a comet. It would take a big iron meteorite to make a big wide hole.
Are you going to live at the bottom of a 30 km deep hole, or in the sunlight on the crater floor?
" Some of the biggest craters on Earth may come from comets."
https://www.seti.org/comets-path-earth
At the bottom of the crater.
Do you mean on the crater floor, or at the bottom of the deep hole in the crater floor?
I saw what you did there.
And how many of them are 30 km deep?
@darkdave3000
I suspect that you have not yet accepted that the hydrostatic pressure gained by going down a deep hole, will be lost again in the pipe rising back up to your habitation. The deep hole and the pipe are quite redundant, you will still have to place a solar-powered air compressor on the surface, close to your habitation.
“The only interesting answers are those which destroy the question”. —Susan Sontag
Baluncore said:
@darkdave3000
There are no pipes or holes in the crater.
You're googling the wrong thing. If you Google for the largest crater in the solar system you get this:
The largest confirmed impact basin in the Solar System is the South Pole-Aitken Basin, located on the Moon. This colossal impact structure is typically described as a broadly circular structure with a diameter of around 2,500 km (1,553 mi) and a maximum depth of around 13 km (8 miles).
Regarding impact craters, I think there are sufficient number of responses here, I would not beat that direction any further.
But, additionally you might need to consider the issue of sunlight in the bottom of that imagined enormous hole. The deeper the hole is, the shorter the 'day' there => what you get is actually an icy hole instead of a paradise.
Thread moved to the Sci-Fi forum
Do we want the SciFi section to becomes the dustbin for the rest of PF?
Think of it as palliative care for a thread...
Why would you drop icy comet(s) on Mars when 'a shower of rocks' would release ample volatiles locked in the ice-caps ??
Also, regardless of the initial crater depth, crust/mantle structure etc, the material would be sufficiently shattered to 'slump' rapidly. Perhaps aided by released volatiles...
FWIW, perhaps better to tunnel adits into canyon flanks, accessing water table / permafrost strata, and only needing modest air-locks plus flexible lining to contain atmosphere...
Alternatively, there are three kinds of medical treatments: diagnostic, therapeutic and punitive.
The OP asked a question, which took us a little while to puzzle out. He got an answer, which he didn't like. Now it's science fiction?
I did look up the craters in the solar system. I was unable to find a single one as deep as the OP wants. That includes Mimas, which has one that nearly destroyed it, and the southern half of Vesta, which arguably did. You can buy a piece of Vesra through the mail these days.
I strongly suspect that there is no process that will make a hole like this without collapse. (Just as you can't pile rocks up arbitrarily high)
Now, Niven did invent a world, "Canyon" that was sort of like this (and I deserve a reward for re-railing this thread) but Niven's science was straight outy of the 60's and even so wasn't always 100% right. But Canyon!" is a poor rebuttal to "this won't work on Mars."
I would categorize Olympus Mons as arbitrrarilly high although it wasnt piled. Im just still struggling with the idea of the volatiles in the comet, if they can some how act as a coolant for the molten slag to harden prematurely before rising up to fill.
I've been beaten up before because of the color of my skin I can take intellectual bullying too! The sci fi is a nice hidden insult!
A. The fact that Olympus Mons is x meters tall does not mean you can dig a hole x meters deep. Both have limits, but not the same limit.
B. Mount Olympus isn't 30 km tall anyway.
This remionds me of the old saw "How many legs does a horse have if you call a tail a leg?" "Four. Calling a leg a tail doesn't make it one."
That just does not works like that. The 'molten slag' takes up only a small portion of the explosion (and even that'll scatter, won't participate directly in the crater formation): most of the energy goes to the gravel (creation and move).
The depth/width ratio of the crater mostly depends on the depth of penetration of the incoming object.
The depth of penetration (with a given, rocky surface) is ~ about the structural strength.
A 'dirty snowball' (comet) does not have much of that. Most likely it would leave a wide but shallow crater only.
At 20+ km/s the entire impactor is going to be superheated and vaporized, no matter what its made out of. There will not be any 'coolant' anywhere. Also remember that the further down you go, the greater the subsequent uplifting as the material attempts to reach gravitational equilibrium. It is this that ultimately limits the depth of holes on any planetary body. What that depth is on Mars, I don't know, but 30 km is probably fairly close.
No one is bullying or insulting you. I suspect Berkeman is actually being nice by moving your thread here, as the rules are somewhat more relaxed here in the sci-fi forums than the main forums.
I doubt anyone on PF knows how to do this except via a rough back-of-the-envelope calculation. That's probably one of the main reasons you haven't gotten any strict yes/no answers.
Well, it's probably calcuable numerically, but I sure wouldn't want to propose it. I can hear the laughter now.
We can look at impacts in the solar system and we have our answer.
  • No impact has left a crater this deep
  • The OP doesn't just want "deep", he wants "small" (or "narrow") and deep craters are large - and get a lot larger and only a little deeper.
  • We have evidence of impacts that have severely disrupted the target body - Mmas, Vesta - and they don't leave craters this big. Increase the impactor's energy and you don't get a bigger crater; you get more asteroids.
Thanks for this useful answer. So would raining down smaller ice rocks at slower speeds say a cluster of 20 x 1km diameter at 8km/s encourage the water ice to act as a coolant? Im thinking like a civil engineer trying to get the structure I want using comets as a sort of a "tool". Im hoping to find the magic formula between speed, mass, size, angular spin, strike angle, cluster size etc. I guess at this point it doesn't look like I'll get any encouraging answers. But thought I throw this out in the forum just in case there is some brilliant person out there watching that can help me out if he can see an angle.
A good rule of thumb is that the kinetic energy of an object moving 10,000 feet/sec (3 km/sec) is equal to the energy of an equal mass of high explosive. Then keep in mind that kinetic energy is proportional to the square of the speed.
So the kinetic energy of an object at 8 km/sec is 7 times the explosive energy of an equal mass of high explosive. The relative cooling effect of water vs rock completely disappears. In fact, as a first order approximation, the damage of an object at 8 km/sec is almost the same if it's ice or high explosive.
Thanks for this! So what if I moved an ice rock from the asteroid belt say a 20km diameter one and crashed it into Mars as slow as possible say 2km/s? The Asteroid Belt does not have as much potential difference in gravitational energy as compared to kuiper belt objects as you know so we should be able to manage a lower delta V in this case. What do you predict would happen in such a scenario?
Baluncore said:
@darkdave3000
There's no pipe here in my hypothetical scenario.
Drakkith said:
At 20+ km/s the entire impactor is going to be superheated and vaporized, no matter what its made out of. There will not be any 'coolant' anywhere. Also remember that the further down you go, the greater the subsequent uplifting as the material attempts to reach gravitational equilibrium. It is this that ultimately limits the depth of holes on any planetary body. What that depth is on Mars, I don't know, but 30 km is probably fairly close.No one is bullying or insulting you. I suspect Berkeman is actually being nice by moving your thread here, as the rules are somewhat more relaxed here in the sci-fi forums than the main forums.
Thank you Berkman!
You are doing this the wrong way. You have postulated that a 30km hole will produce an acceptable environment (including structural stability). You need to be working towards proving this. These “how to make it“ discussions are a distraction.
Hi sorry, I thought I already mentioned Mars has a 11.1km scale height. Do you know how scale heights work?
