Can Derivative Methods Determine the Correct Angle in Physics Problems?
Tapias5000
Determine the moment of the force with respect to point O as a function of θ . for what value of θ in the range between 0° and 180° is the moment at its maximum? what is the value of the moment in this case?
Mo= R x F
This is the image of the problem:
Physics diagram of a curved arm of radius 3 m pinned at point O on the left, with a 500 N force arrow applied at its free end on the right, and angle theta measured from the horizontal at the arc centre.
I tried to solve it and I got the following is it correct?
Handwritten solution and diagram: a curved arm of radius 3 m pivoted at O carries a 500 N force at its end, with angle theta from the horizontal, and the moment M_o = 1500 sin(theta) N·m is derived using a cross product and differentiated.
derive and equal to 0 because it is between an angle of 0 and 180° is this statement correct?
Looks fine, though you should specify units everywhere, e.g. ##1500\sin(\theta)Nm##.
You can take the point of action of a force as anywhere along its line of action, so it is simpler to consider the force acting at the centre of the arc. The horizontal component then has no moment about O, and you can write the answer down immediately.
Btw, you put "momentum" in the title instead of "moment".
ok, but I still need to find the angle, is the statement I said correct to find it?
Yes.
