Can Discrete Logarithms Be Added in Modular Arithmetic?
16 replies · 2K views
fishturtle1
Let g be a primitive root for ##\mathbb{Z}/p\mathbb{Z}## where p is a prime number.
b) Prove that ##\log_g(h_1h_2) = \log_g(h_1) + \log_g(h_2)## for all ##h_1, h_2 \epsilon \mathbb{Z}/p\mathbb{Z}##.
Let x, denoted ##\log_g(h)##, be the discrete logarithm of g to the base g. Then ##g^x \equiv h## (mod p).
In part a) I showed : Suppose that ##x = a## and ##x = b## are both integer solutions to the congruence ##g^x \equiv h## (mod p). Prove that ##a \equiv b## (mod p - 1).
Attempted proof:
We have ##g^{\log_g(h_1)}g^{\log_g(h_2)} \equiv h_1h_2## (mod p). So
##g^{\log_g(h_1) + \log_g(h_2)} \equiv h_1h_2## (mod p).
We know ##\log_g(h_1h_2) \le p - 1## must be true. But ##\log_g(h1) + \log_g(h_2)## could be greater than p - 1. So, even though they are congruent modulo p - 1, they might not be equal. Let ##\log_g(h_1) + \log_g(h_2) = (p - 1)q + r## where ##q, r \epsilon \mathbb{Z}## and ##0 \le r < p -1##. Using Fermat's Little Theorem, we have
##g^{\log_g(h_1) + \log_g(h_2)}g^{q(p - 1)} \equiv h_1h_2(1)^q## (mod p).
##g^{\log_g(h_1) + \log_g(h_2) + q(p - 1)} \equiv h_1h_2## (mod p).
Taking the log of both sides, we get
##r \equiv \log_g(h_1h_2)## (mod p).
and since ##r < p - 1## and ##\log_g(h_1h_2) < p - 1## we can conclude
##r \equiv \log_g(h_1h_2)## (mod p - 1).
But ##r## and ##\log_g(h_1) + \log_g(h_2)## are just elements of the equivalence class ##[r]## in ##\mathbb{Z}/p\mathbb{Z}##. So we can conclude by transitivity ##\log_g(h_1) + \log_g(h_2) \equiv \log_g(h_1h_2)## (mod p - 1). []
edit: sorry, I keep reading this question wrong, but this is the same stuck point I've gotten a few different ways... I'm not sure how to go from here, to the ##\log_g(h_1h_2) = \log_g(h1) + \log_g(h2)## for all ##h_1, h_2 \epsilon \mathbb{Z}/p\mathbb{Z}##.
fresh_42 said:
I think this is far too complicated. Why don't you set ##h_1 = g^x\; , \;h_2 = g^y \; , \; (h_1h_2)=g^z## (do they exist?), and show ##x+y \equiv z \operatorname{mod} p## ?
Thanks for the reply.
So we can have ##h_1 = g^x\; , \;h_2 = g^y \; , \; (h_1h_2)=g^z##. These numbers definitely exist because ##g## is a primitive root of Z/pZ, so it generates Z/pZ. Also, ##x , y, z < p##. So, ##g^xg^y = g^{x + y} = g^z##. Using the discrete logarithm, we have ##\log_g(g^{x + y}) = \log_g(g^z)##, which simplifies to ##x + y \equiv z## (mod p).
I think from "So, ##g^xg^y = g^{x + y} = g^z##." I could conclude that x + y = z and i'd be done. But doing that I wouldn't use the discrete log and I'm pretty sure i need to use it.
fresh_42 said:
You don't use it, since you want to prove it. But ##g^xg^y=g^{x+y}=g^z## gives you ##g^{x+y-z}=e## and thus ##x+y-z \equiv 0 \operatorname{mod} p##. This way the logarithm is only needed to define ##x,y,z##.
Thank you, I didn't think of that.
Let ##h_1 = g^x, h_2 = g^y## and ##h_1h_2 = g^z##. So we have ##g^xg^y = g^{x+y} = g^z##. Multiplying by ##g^{-z}## we get ##g^{x+y-z} = e##, where e is the identity. Taking the discrete log of both sides, we get ##x + y - z \equiv 0## (mod p). Adding ##z## we get ##x + y \equiv z## (mod p). By definition of the discrete log function, ##0 < x + y - z \le p - 1##. That is, ##x + y = (x + y - z) + m(p - 1)## for some integer m and ##z = (x + y - z) + n(p - 1)## for some integer n.
Am I not understanding something? It seems like the ##\log_g(h_1) + \log_g(h_2) = \log_g(h_1h_2)## isn't always equal for any ##h_1, h_2 \epsilon \mathbb{Z}/p\mathbb{Z}## since it isn't clear that ##m = n##.
Why do you take the logarithm? Any equation ##a^n=e## in ##\mathbb{Z}/p\mathbb{Z}## means ##n \equiv 0 \operatorname{mod} p##. Therefore ##x+y\equiv z \operatorname{mod} p##. Now all we have to do is to re-substitute what ##x,y,z## mean: ##x=\log_gh_1 \ldots##
If i follow you, you are saying once we have ##x + y \equiv z \operatorname{mod} p##, we just use our variables from before and say ##\log_g(h_1) + \log_g(h_2) \equiv \log_g(h_1h_2) \operatorname{mod} p##?
edit: sorry if your point is going over my head, but i don't see how this would prove the original statement.
Like what if ##\log_g(h_1) + \log_g(h_2) > p - 2##, then ##\log_g(h_1) + \log_g(h_2) \neq \log_g(h_1h_2)##
Yes.
I don't think that you can lift the equation from ##\mathbb{Z}_p## to ##\mathbb{Z}## other than deliberately choosing the smallest representative, so the equation in ##\mathbb{Z}_p## is all you can get. E.g. if ##\log_g h_i = p-1## what will you do? ##\log_g(h_1)+\log_g(h_2)=2p-2 > p## but according to your definition ##\log_g (h_1h_2) < p##.
fresh_42 said:
Yes.
When I wrote ##\mathbb{Z}/p\mathbb{Z}##, I really meant ##\mathbb{F}_p^*##, where ##\mathbb{F}_p^*## = ##\mathbb{Z}/p\mathbb{Z} - \lbrace 0 \rbrace##, my mistake. Also, discrete log is defined as ##\log_g : \mathbb{F}_p^* \rightarrow \mathbb{Z}/(p - 1)\mathbb{Z}##.
it seems we can disprove the statement with a counterexample.
Let ##p = 17##, ##g = 3## where ##g## is a primitive root of ##\mathbb{F}_{17}^*##. We know in this field, ##3^7 = 11, 3^{13} = 12##. Thus ##\log_3(11) + \log_3(12) = 7 + 13 = 20##. Also, ##11 * 12 \equiv 13 \operatorname {mod} 17##. So ##\log_3(132) = \log_3(13) = 4##.
Since ##20 \neq 4##, we can conclude ##\log_g(a) + \log_g(b) \neq \log_g(ab)## for some ##a,b \epsilon \mathbb{F}_p^*##. []
Your are right, I missed the zero. From ##g^x\cdot g^y = g^z \,(p)## we must conclude ##x+y=z \,(p-1)## because we have one element less. Now we get ##\log_g (h_1 \cdot h_2) = \log_g (h_1) + \log_g(h_2) \operatorname{mod} p-1##. ##g## generates ##\mathbb{F}^*_p## which has ##p-1## elements.
In your example this is ##7+13 = 4 \,(16)\,##, because ##\log_g e = 16 = 0##.
Thank you for your response.
When you say ##g^x\cdot g^y = g^z \,(p)##, why is there a ##(p)##?
What does ##\log_g (h_1 \cdot h_2) = \log_g (h_1) + \log_g(h_2) \operatorname{mod} p-1## mean? I thought if we are comparing two quantities with "mod p - 1", then we can only say they are congruent, not equal.
I don't understand how ##7 + 13 = 4(16)##. I kind of see that ##\log_g(e) = 16 = 0## but Fermat's Little Theorem tells us ##a^{p - 1} \equiv 1 \operatorname {mod} p## but not that ##a^{p - 1} = 1##. So shouldn't all these ##=##s be ##\equiv##'s?
Another question: ##\max\lbrace \log_g(h_1) + \log_g(h_2)\rbrace = p - 1 + p - 1 = 2p - 2##. And ##\max\lbrace \log_g(h_1h_2)\rbrace = p - 1.## Therefore, we could have the case where ##\log_g(h_1) + \log_g(h_2) = 2p-2 \equiv p - 1 \operatorname (\mod p - 1) = \log_g(h_1h_2)## since ##2p-2 = (p - 1) + 1(p - 1) \rightarrow 2p-2 = (p - 1) \operatorname (\mod p - 1)##.
##\mathbb{F}_p^* = \langle g \rangle## is a cyclic group with ##p-1## elements, and ##g## generates it. Thus we can write ##h_1=g^x## and ##h_2=g^y## for some ##x,y## with ##0 \leq x,y < p##. Now ##h_1h_2=g^{x+y}=g^z## with a ##0\leq z < p##. This means ##g^{x+y-z}=e## or ##(p-1)\,\vert \,(x+y-z)\,##, which can be written as ##\log_g(h_1h_2)=z=x+y=\log_g(h_1)+\log_g(h_2) \,\operatorname{mod} (p-1)##.
The equation ##g^{x+y}=g^z## is an equation of elements of ##\mathbb{F}_p\,##, which means it holds modulo ##p##.
So for your example:
##11 \cdot 12 = 3^7 \cdot 3^{13} = 132 = 3^4 = 13 \,\operatorname{mod} (17)##
and
##\log_3(11 \cdot 12) = 4 = 20 = 7+13 = \log_3(11) + \log_3(12) \,\operatorname{mod}(16)##
I think I understand what you mean, here's a proof in based on what you've said in my own words:
Proof: Let ##x = \log_g(h_1), y = \log_g(h_2), z = \log_g(h_1h_2)##. Since ##g## is a primitive root of ##F_p^*##, g must be a generator of ##F_p^*##. Thus ##0 < x, y, z < p##. We have ##g^xg^y = g^{x + y} = g^z##. Multiplying by ##g^{-z}##, we get ##g^{x+y-z} = e## where ##e## is the identity element of ##F_p^*##. But ##e = 1##. So by Fermat's Little Theorem, it follows ##(p - 1) | (x + y - z)##. So ##x + y = z + (p - 1)k## for some integer k. Therefore ##x + y \equiv z (\operatorname {mod} p - 1)##. Since ##x, y, z \epsilon F_p^*##, it follows x + y = z, that is, ##\log_g(h_1) + \log_g(h_2) = \log_g(h_1h_2)##. []
##0 \leq x, y, z## since ##h_i=e## isn't ruled out and ##\log_g e = 0##.
The last equations ##x + y = z##, resp. ##\log_g(h_1) + \log_g(h_2) = \log_g(h_1h_2)## are only true modulo the number of elements in the group generated by ##g##, which is ##p-1##. E.g. in your example you have ##7+13=20## but ##\log_3(132)=4##. You cannot lift the equation back into the integers, because in ##\mathbb{Z}## is ##20 \neq 4## whereas in ##\langle 3 \rangle = \mathbb{F}^*_{17}## we have ##20 = 4##.
My confusion has been with the original statement ##\log_g(a) + \log_g(b) = \log_g(ab)## where ##a, b \epsilon \mathbb{F}_p^*##. Since ##a,b \epsilon \mathbb{F}_p^*##, we need to show ##\log_g(a) + \log_g(b) = \log_g(ab) \operatorname {mod} (p - 1)##, like you said.
I"ve been doing this problem as if ##\log_g(a), \log_g(b) \epsilon \mathbb{Z}## and could be outside of ##\mathbb{F}_p^*##. I think that's where my confusion has been..
so my proof would be:
Proof: Let ##x = \log_g(h_1), y = \log_g(h_2), z = \log_g(h_1h_2)##. Since ##g## is a primitive root of ##F_p^*##, g must be a generator of ##F_p^*##. Thus ##0 \le x, y, z < p##. We have ##g^xg^y = g^{x + y} = g^z##. Multiplying by ##g^{-z}##, we get ##g^{x+y-z} = e## where ##e## is the identity element of ##F_p^*##. But ##e = 1##. So by Fermat's Little Theorem, it follows ##(p - 1) | (x + y - z)##. So ##x + y = z + (p - 1)k## for some integer k. Therefore ##x + y \equiv z (\operatorname {mod} p - 1)##. By substitution, ##\log_g(h_1) + \log_g(h_2) \equiv \log_g(h_1h_2) \operatorname {mod} (p - 1)##. So, ##\log_g(h_1) + \log_g(h_2) = \log_g(h_1h_2)## where ##h_1, h_2 \epsilon F_p^*##.[]
So far so good, and I think, so done as well.
This last sentence isn't necessary. ##h_i \in \mathbb{F}_p## anyway so you only state, that ##h_i \neq 0## resp. that ##\log_g(0)## isn't defined. This information has nothing to do with the proof, only with the definition of ##\log_g\,##. What is important, is that all numbers ##\log_g(h_i)## are in ##\mathbb{F}^*_p##, because this group has less elements, so the equation is modulo ##p-1##. So it doesn't matter where ##h_i## are from at this point, but it matters where ##\log_g(h_i)## are from, which you already said before.
Ok I understand and took out the last sentence of the proof. Thank you for your time and help on this proof.
