Can I Create a Calibration Curve Using Only Peak Area Data?
  • Thread starter Thread starter CannonSLX
    Calibration Curve
8 replies · 3K views · last reply
CannonSLX
I've just done an ion chromatography experiment and have normalized my data for a known sample which has a known concentration of 10ppm.
I know that the first large peak is due to F- ions and so the area of the peak is propositional to the concentration of the ion.
Given that I know the area, how can I get the calibration curve just by this information ?
Assume signal would be zero if there were no F- at all, that gives you two pints, enough to draw a straight line.
That's not the best approach in general, but better than nothing.
Thanks, but I'm not sure I fully understand.
This is my current data graph; https://i.gyazo.com/72d8f842cc504e924d1d0f106fb0266a.png
The first large peak corresponds to F- ions.
If I assumed the signal as 0 how would I plot a calibration curve ? Would it be possible for me to choose 2 points on the curve which produce a linear relationship ?Thank you in advance for your help :)
You know the area of a peak that correspond to a 10 ppm concentration, yes?
Assume 0 ppm would produce no peak - or a peak of area 0.
That gives you two points for calibration curve - one for 0 ppm concentration and one for 10 ppm concentration.
I see, thanks.
To calculate the area, can I normalise my data so that the area under the curve is directly po
Thanks. I've managed to do it and used excel to calculate the gradient, in the form y=mx+c
One last question.
If I run a sample with an unknown concentration of F-, if I know the area under the curve (y) and the gradient (m), knowing that c=0, would I just solve for (x) which would be my concentration of F- in the unknown sample ?
You lost something here. You can use peak height instead of the area, typically these are related (and in the case of a nice curve - like the one you have - it is quite good approach).
Yes.
Yes.
We've been told to use area, so would normalising be the right idea for this approach ?
Borek said:
If you are told to use area - use area.
Thanks for your help :)
