Can Sequence r_n Be Bounded by O(log2(log2 n))?
49 replies · 7K views
NATURE.M said:
Oops I missed that. In that case, can't we just let c = 1, at the beginning of the proof since the definition of big oh asks for you to choose a c. (∃c∈ℝ+).
Sure. The choice for c is 1 or greater. Since you'd generally look for the tightest bound, choose 1.
Ok. And also just realized that n has to be ≥3 otherwise the proof fails. Namely, in the definition of big oh our choice of B should be 3. Since n = 1 is undefined for the double log term and n=2 doesn't satisfy the predicate with c = 1.
OK.
All done?
haruspex said:
OK.
All done?
Yeah I believe that is it. I can't thank you enough for your efforts and being patient with me throughout.
A pleasure.
haruspex said:
A pleasure.
So it turns out when I was writing the proof, I stumbled upon a little issue. Basically, in order to be able to use the IH on rfloor(√n) we require 3 ≤floor(√n) < n which is just not the case. Like take n = 3, then floor(√3) < 3. Even if you try to lower bound floor(√n) by 0 or 1 it doesn't work since then the log term in the predicate becomes undefined. In other words, P(n) just isn't true for n = 0, 1. This is rather unfortunate. I'm not really sure how to get around this ?
You could change your base step to something like: P(n) is true for 3 ≤ n ≤ 8.
Okay that makes sense. So if i understand correctly, I can prove each individual case from let's say 3≤n≤8. Then proceed with complete induction from 8≤k<n. Would that make sense ? Because then when I do the proof, I wouldn't by just invoking the IH, I would also have to specify the truth of the base cases.
No, it'll be a problem if you change your IH. You could instead formulate it as:
Base step: Show that P(n) is true for 3 ≤ n < 9.
Induction hypothesis: P(k) is true for 3 ≤ k < n.
Induction step: Assume IH holds, and show that P(n) is true for n ≥ 9.
Would it necessarily? Seems to me it could be generalised to rn <= A + B l2 l2 n. With the same algebra as before, the A's cancel out and again produce B>=1.
Yes, the base of the induction needs to be broadened. If we make the base N0 <= n < N1, we need N1 >= N02. As you say, keeping N0=3 means means 3 to 8 have to be demonstrated separately to satisfy the IH, but consider N0=2. We need r2 = 2 <= A + B l2 l2 2 = A.
But a new issue i just noticed that none of the base cases satisfy if we take c = 1. Like r3 = 2, and r
Should i choose c = 4 instead ?
Did you see my post #40?
It was probably not clear, but I just meant that the OP should keep the IH as 'P(k) is true for 3 ≤ k < n' instead of 'P(k) is true for 8 ≤ k < n'.
How do the A's cancel?
##r_n = 1 + r_{\lfloor\sqrt{n}\rfloor} \leq 1 + A + B l_2 l_2 (\lfloor\sqrt{n}\rfloor) \leq 1 + A + B l_2 l_2 (\sqrt{n}) ##
##= 1 + A + B (l_2 l_2 (n) - 1) = 1 + A -B + B l_2 l_2 (n)##.
If B >= 1, ##1 + A -B + B l_2 l_2 (n) \leq A + B l_2 l_2 (n)##.
With A=2, that IH is true for n = 2, 3. The induction takes it from there.
Okay what does the A represent ? If I'm not mistaken the B is just c but what's the A term ?
Otherwise I understand what your saying.
A is just adding a sufficient buffer to ensure that the IH is true (with the least possible B) as soon as possible. With A=2 you get to start the IH at n=2. It doesn't affect the asymptotic behaviour.
Making B as low as possible, at the expense of a larger A, gives the asymptotically tightest bound. You could instead start the IH at a higher n0, but as we have seen that requires a lot more calculation because you have to cover from n0 to n02-1 by hand.
Oh that makes a lot of sense. So more generally, we can write f is in 0(g(n) + A) and it wouldn't actually make a difference since A is only a constant.
SammyS said:
Try writing out the first part of the sequence. It increases very slowly, which is not a surprise, considering what you're asked to prove.
For what values of n is ##\ r_{n+1}>r_n \ ## ?
As I mentioned in Post #9 above:
I would have approached this problem somewhat differently. Look at how this sequence progresses.
r2 & r3: ## \ \lfloor \sqrt{2}\rfloor=\lfloor \sqrt{3}\rfloor=1 \ ## Therefore, r2 = r3 = 1 + r1 = 2 .
r2 and r3 both refer to r1, so they have the same value.
The smallest n for which rn refers to r2 is n = 4, a perfect square, in fact 22.
The smallest n for which rn refers to r3 is n = 9, in fact 32. But r2 = r3 there is no increase going from r8 to r9.
The smallest n for which rn refers to r4 is n = 42 = 16. Note that: r4 = ... = r15 = 4.
From here, there are a whole slew of n values for which the rn refer back to these members of the sequence having value of 4. Starting with r16 they all have a value of 5.
The smallest n for which rn refers to r16 is n = 162 = 256. ...
So, r1 = 1
rn increases to 2 when n goes to 2.
rn increases to 3 when n goes to 4 = 22.
rn increases to 4 when n goes to 16 = 42 = (22)2.
rn increases to 5 when n goes to 256 = 162 = ((22)2)2.
You can relate the value of rn to the overall exponent on 2 for the value of n at which rn is incremented. Perhaps induction may be used to prove that this relationship holds for each value of n and/or rn .
So, r1 = 1
Seems like a lot more work than the solution already posted.
Perhaps.
... but, it wasn't clear to me that OP had fully comprehended the details of that solution.
