Can the Function x^2 * exp(-x/a) = b Be Solved for x Using Lambert W?
  • Thread starter Thread starter Beer-monster
    Function
4 replies · 2K views
Beer-monster
It could be the late night, but a problem I've been doing results in a function of the form
[tex]x^{2}exp\left(\frac{-x}{a}\right) = b[/tex]
Where a and b are constants. I'm not sure how to go about solving for x.
I've trying taking natural logarithms of both sides but that doesn't seem to help me too much.
Any help would be appreciated. I get the funny feeling I've seen this before.
You require the Lambert W function, defined as the inverse of the function x e^x. That is, if W(x) is the Lambert W function...
[tex]W(x) e^{W(x)} = x[/tex]
Thanks for the reply.
I looked up the Lambert W function, but not quite sure how to apply it in my circumstances. Most of the stuff I find online on the topic seems a little opaque to me:confused:
I did try another method which is to rearrange the equation into:
[tex]exp\left(\frac{-x}{a}\right) = \frac{b}{x^{2}}[/tex]
Now, since I'm only interested in a specific value of x (x=X) corresponding to a saddle point (the above is the result of differentiating and setting to zero) I thought I could use the Taylor series of the exponential function and take the first term. So:
[tex]exp\left(\frac{-x}{a}\right) \approx 1-\frac{x}{a}[/tex]
This means I can take the first term (1) and then rearrange to solve for X.
[tex]\frac{b}{x^{2}}=1[/tex]
However, I realize now that this only applies for x = X = 0. So, as far as I can tell that means I'm back to:
[tex]exp\left(\frac{-X}{a}\right) = \frac{b}{X^{2}}[/tex]
Is that correct? I feel like I'm missing something because I almost felt I had it.
Unfortunately, with that extra "x" in there, you cannot solve this equation with the Lambert W function, for the same reasons you cannot solve [math]xe^x= b[/math] with the logarithm function. Of course, we could define the "Beer-Monster", BM(x), to be the "inverse function to [math]f(x)= x^2e^{x}[/math] (well,for x> 0 we can- this function is not one-to-one for all x and so does not have a true "inverse").
If y= -x/a, then x= -ay so [itex]x^2e^{-x/a}= a^2y^2e^{y}= b[/itex],
[tex]y^2e^{y}= \frac{b}{a^2}[/tex]
and so
[tex]y= BM\left(\frac{b}{a^2}\right)[/tex]
and, finally,
[tex]x= -ay= -aBM\left(\frac{b}{a^2}\right)[/itex]<br /> is the negative root to the equation.[/tex]
and so
and, finally,
[tex] <br /> I must humbly beg to differ. <a href="http://www.wolframalpha.com/input/?i=x^2+e^(-x/a)+%3D+b" target="_blank" class="link link--external" rel="nofollow ugc noopener">As you can see</a>, Wolfram-Alpha gives a solution for x that involves only the Lambert W function and the square root function.[/tex]
