Can the Moon form a smiley face between Venus and Jupiter?
17 replies · 4K views · last reply
swampwiz
I was reading this:
http://www.physics-astronomy.com/2020/04/set-your-alarm-jupiter-venus-and-moon.html
It seems that for this to happen the Moon would need to be in-between the pair of planets and the Sun - but the Sun's path defines the Ecliptic, and the bright planets are all very close to the Ecliptic, certainly closer than the size of the Moon.
No reason why it's not possible.
Moon is only 1/4 degree wide.
Simulated night-sky view on a black background showing a thin crescent Moon with two small yellow dots, likely planets, to its right, a dotted red horizon line, and a white scale bar labelled 1 degree.
After checking a couple of resources (Celestia, World Wide Telescope, and Horizons web site), I've come to the conclusion that this supposed meeting up isn't going to happen. On that day, none of these bodies are even in the same part of the sky according to any of them. The Moon isn't even that much of a crescent. Now on May 16, 2010, the Moon was a thin crescent, and Venus was also in the right part of the sky, (both in Taurus) but no Jupiter(It was in Pisces). I think this might be another of those "Mars will appear as large as the Moon" things.
Hmmm...
Given the 'classic" smiley face..
Classic yellow smiley face emoticon with two oval black eyes and a curved black smile, outlined in black on a white background.
It appears impossible because the planets would be behind the moon.
If you instead want to say, "Yeahbut I'm looking for an approximate smiley face, I think you need to tell us how close is close enough.
How about close enough to entice astro-virgins off the couch to go out and gaze at the Heavens, possibly inspiring new hobbyists?
Assume a spherical smiley face...there is a joke here somewhere but I seem to have lost it.
It is just the right time of year here...no bugs and maybe a sweatshirt...
DaveC426913 said:
Fourmilab's virtual telescope suggests Jupiter and Venus are nearby, though a pretty lopsided smiley.
http://www.fourmilab.ch/cgi-bin/Yourtel
Interesting. World Wide Telescope shows this for the relative positions of Jupiter and Venus for this date
( arrows are sight-line from earth).
Celestia screenshot of the Solar System from above the ecliptic, with the Moon marked near the top and a cyan line drawn from Earth to it, showing the date 2020/05/16 17:00:46.
Celestia shows this Looking over the Earth towards the Moon, neither Jupiter or Venus are shown close, though Neptune is in the picture.
Celestia screenshot of the Moon orbiting Earth, with Earth and Neptune labelled against a starfield, two red orbit lines and a readout of distance 1,116,500 km.
You have to rotate the view quite a bit to see Venus, and by then the Moon is well off to the side of its orbit in relation (white dot on right side of red ellipse over by Mercury in the image).
Celestia screenshot of the Moon's orbit around Earth as a red ellipse, with the labels Earth, Venus and Mercury and a date stamp of 2020 May 16 17:19:14 DST.
Going by the Dec and RA given by the Horizons site, these are the positions of the three on that date:
Star chart of the celestial sphere in a wide projection, showing constellation outlines and labelled constellation names; Moon, Jupiter and Venus are marked in orange with their names.
While the Moon and Jupiter look close in this image, it is a 360 degree wrap- around, and they are over 45 degree apart in the sky. Venus is over 90 degrees away from the Moon (which agrees with Celestia)
I wonder why the discrepancy from what you found?
Dunno. But I'd trust a virtual telescope with a view of the sky from Earth over - er - spitballing it from a sim of the Solar System, but YMMV.
[EDIT]
I've changed my mind.
'In the sky' seems to be giving me similar results to yours.
https://in-the-sky.org/whatsup.php?year=2020&month=4&day=18&town=6167865
I'm wondering if this is a hoax - that it occurred on that date in some other year and they've just updated the year.
But the planets would need to be that much off of the Ecliptic so that the Sun would be on the other side of the Moon from the planets.
EDIT: OK, it looks like Venus & Jupiter are 3.4 & 1.3 degrees off the Ecliptic plane, so the Moon could just barely nudge itself in between, but it would still be "daytime" dawn/dusk so the planets would not be visible, and the terminator on the Moon would almost completely encompass the whole disk.
A minor point, but to be accurate the moon is 1/2 a degree wide.
On may 16, 2010, this is what you would have seen from Perth, Australia (Sun below horizon).
Dark night sky star field with a circled dot labelled Venus near the top, a circled crosshair marker near the lower left, and several faint stars scattered around.
And on Dec 1, 2008, you could have seen this:
Star chart on black background showing a crescent Moon near the lower left, with the labels Venus and Jupiter in red near upper and right planets.
Not exactly the image being promoted, But I think we can be pretty sure that this recent one is a hoax.
I hadn't thought of a pair of planets being at the same "hour angle" along the Ecliptic (whatever that is called) with the separation due to the angle of their respective orbital plane with respect to the Ecliptic. With that as a possibility, it's no problem for the Moon to be the proper smiley position. I could see a very good popping up every once in a long while!
Dang it! I knew that, and overrode my first answer. (Google said radius is .26. Oops.)
On the night of 1 December 2008, there was a frown. Below is a screen shot for this event from the Stellarium app on my laptop.
Stellarium planetarium screenshot of a dark sky showing a thin crescent Moon with labels, Jupiter and Venus, at 17:30:21 on 2008-12-01 from Prince George, Earth.
Vanadium 50 said:
Hmmm...
Is it possible for a Moon and two planet smiley face to wink as Moon occults two planets simultaneously and then both planets emerge from dark side of Moon, not quite simultaneously?
It depends on where in the world you viewed it from. The Moon moves at about 1/2 degree per hour relative to the stars. Thus the time of day you are viewing it on that particular day will determine its relative position with respect to Jupiter and Venus. Where you are in the world will determine what you would see while the Moon is above the horizon and the Sun below it. So in Argentina on that date sometime after sunset, you would see something like your image. However, just after sunset in western Australia, You would see that arrangement shown in my image. This is because of the time difference between sunset in Argentina and in Australia and how much the Moon moves relative to Jupiter and Venus in the intervening hrs.
