Complex number epsilon-delta problem
11 replies · 2K views
jjr
Prove that [itex]\lim_{z\rightarrow z_0} Re\hspace{1mm}z = Re\hspace{1mm} z_0[/itex]
It is specifically mentioned in the text that the epsilon-delta relation should be used,
[itex]|f(z)-\omega_0| < \epsilon\hspace{3mm}\text{whenever}\hspace{3mm}0<|z-z_0|<\delta[/itex].
Where [itex]\lim_{z\rightarrow z_0}f(z) = \omega_0[/itex]
Other equations that might be useful are
[itex]|z_1+z_2| \leq |z_1| + |z_2|\hspace{3mm}\text{(Triangle inequality)}[/itex]
and perhaps
[itex]Re\hspace{1mm}z \leq |Re\hspace{1mm} z| \leq |z|[/itex]
Here [itex]\omega_0 = Re\hspace{1mm}z_0[/itex] and [itex]f(z) = Re\hspace{1mm} z[/itex],
so we want to find a delta [itex]|z-z_0| < \delta[/itex] such that [itex]|Re\hspace{1mm}z - Re\hspace{1mm}z_0| < \epsilon[/itex].
I am honestly not sure how to approach this. Any clues would be very helpful.
Thanks,
J
and perhaps
Thanks,
J
Think about it. Which is larger ##|z-z_0|## or ##|Re(z)-Re(z_0)|##?
Well, the distance between two complex points is definitely larger or equal to the distance between the real parts of the same points...
Ok, so how small shall we make ##|z-z_0|## to make sure that ##|Re(z)-Re(z_0)| \lt \epsilon##?
Hmm. I suppose that if we set [itex]|z-z_0|[/itex] smaller than [itex]\epsilon[/itex], then [itex]|Re(z)-Re(z_0)|[/itex] would have to be smaller than [itex]\epsilon[/itex]. I.e. [itex]\delta = \epsilon[/itex]?
Yes.
Thank you. Not too hard to see really, but I'm still not sure how to show it. Is the statement I made sufficient? I feel like it's lacking some rigor
You just need to show ##|Re(z)| \le |z|##.
Okay, I think I've got my head wrapped around it. I have another one, if you would care to have a look:
To be shown:
##\lim_{z\rightarrow z_0} \bar{z}=\bar{z_0}##
So
## |\bar{z}-\bar{z_0}|<\epsilon \to |z-z_0|<\delta##
My work:
I'm trying to find some relation between ##z,z_0## and their conjugates, so I tried setting
##\bar{z}=z-2Im(z)##
##\to |\bar{z}-\bar{z_0}| = |z-z_0-2Im(z)+2Im(z)|##.
Here I tried invoking the triangle inequality, but the expression I ended up with didn't help much.
Suggestions?
Thanks,
J
edit: typo
Hint: [itex]\lvert z-z_{0}\rvert ^{2}=(z-z_{0})(\bar{z}-\bar{z_{0}})=\lvert \bar{z}-\bar{z_{0}}\rvert ^{2}[/itex]
Thank you. I suppose one could take the square root from both sides and obtain ##|z-z_0| = |\bar{z}-\bar{z_0}|##, which in turn enables us to set ##\delta = \epsilon##? Thinking about this again I realize that this makes sense, that the distance between two points ##z, z_0## should be the same as the distance between the same two points mirrored about the imaginary axis.
