What factors contribute to an object's rest energy?
  • Context: High School
  • Thread starter Thread starter etotheipi
    Energy Rest
The discussion centers on the relationship between gravitational potential energy (GPE), rest mass, and rest energy in physics. Participants clarify that while increasing the GPE of an object-Earth system can increase the system's rest energy, it does not necessarily affect the individual object's rest mass. The conversation also highlights the distinction between rest mass and invariant mass, emphasizing that the internal potential energies and kinetic energies of nucleons contribute to the rest energy of a nucleus. A concrete definition of rest energy is sought, focusing on its contributions from various energy forms.
  • Understanding of gravitational potential energy (GPE)
  • Familiarity with concepts of rest mass and invariant mass
  • Knowledge of nucleon interactions and binding energy
  • Basic principles of relativistic energy
  • Research the relationship between gravitational potential energy and rest mass in detail
  • Study the concept of binding energy in nuclear physics
  • Explore the differences between rest mass and invariant mass
  • Investigate the contributions of kinetic and potential energy to the overall energy of a system
Students and professionals in physics, particularly those studying nuclear physics, general relativity, and energy conservation principles. This discussion is beneficial for anyone seeking to deepen their understanding of rest energy and its contributing factors.
etotheipi
My physics textbook states that increasing the GPE of an object will increase its rest mass by E/c^2 , though I don't think this should be the case. I would argue that increasing the GPE of the object-Earth system will cause the rest energy of the system to increase by this amount, whilst that of the the individual object will remain unaffected. It also states that adding heat to an object, increasing its internal energy, will increase its rest mass by E/c^2; this does in fact seem to make sense.
The popular example for this is binding energies: a system of nucleons separated at large distances have a greater total mass than when they are close together in a nucleus, so we observe a mass deficit. Would I be correct in assuming that this is because the internal potential energies of the system have become more negative (i.e. assuming the particles are attracting through the strong force?).
Evidently the term rest energy is the energy in the zero momentum frame, however as of now I have just been thinking of this energy as the sum of many contributions such as internal potential energies. I have also assumed that potential energies due to external fields (e.g. gravitational) do not affect the rest energy of an object since such a potential energy is meaningless (at least at the level I am working at) without considering the whole system. I was wondering if someone could give me a more concrete definition of what constitutes the rest energy?
Taking the example of a nucleus, for instance, I would suspect that the contributions to rest energy - apart from the rest masses of each nucleon - would be internal potential energies of the nucleons, kinetic energy of the individual nucleons (not the KE of the nucleus, which would instead make up the other part of the overall relativistic energy), rotational energy of nucleons etc.
Am I thinking along the right lines?
N.B. I should also add that the intrinsic energies associated with the masses of the e.g. particles in the nucleus will contribute to rest energy, however these alone are not sufficient to explain why rest energies can change.
anorlunda said:
Are you sure he meant rest mass? Possibly he said or meant invariant mass.
https://en.wikipedia.org/wiki/Invariant_mass
I was under the impression that rest mass and invariant mass were the same quantity m0. I could be wrong though since I'm not well versed in this field.
Either you are misunderstanding your textbook our your textbook is wrong. And you are right that the potential energy belongs to the object-earth system and not the object in isolation.
However, increasing the GPE does not necessarily increase the rest mass of the system; that depends on where the energy to lift the object came from. For example, if we dug some coal out of the earth, burned it to make steam, used the steam to generate electricity, used the electricity to run a hoist that lifts the object to increase the GPE... there is no change in the rest mass of the overall system because we’ve just moved energy around within the system.
This one can be tricky; much more than in the earth-object-gravity case you have to be careful to track the energy that enters and leaves the system. But yes, the mass of a nucleus is generally less than sum of the masses of the same number of free nucleons, and the difference shows up in the energy released in the formation of the nucleus.
  • · Replies 46 ·
  • · Replies 21 ·
  • · Replies 102 ·
