Converting logarithmic equations to exponential form and combining logs with coefficients
  • Thread starter Thread starter math4life
    Logarithm
math4life
1) Solve the equation using the exponential form of the equation.
Log2(2-5x)=7
2) Rewrite as a single logarithmic expression:
3log x +(1/2)log z
1) I have no idea how to solve this.
2) I know that two logarithms multiply to add, but these have different bases so I do not know what to do.
Thanks.
math4life said:
Log2(2-5x)=7
Here is a hint.
[tex]a^b =c \Rightarrow b= log_a c[/tex]
3log x +(1/2)log z
they are in the same base. Logx usually means log10x.
Use the rule
[tex]rlog_a x = log_a x^2[/tex]
I'll just fix up rock.freak667's little typo there.
What was meant to be said is: [tex]r.log_a(x)=log_a(x^r)[/tex]
Coupled with the rule that [tex]log_a(b)+log_a(c)=log_a(bc)[/tex]
You should have no problem solving the second one :smile:
I think it might be helpful to add that a logarithm can be thought of as the exponent on the base (the number raised to a power) that results in a particular number. So for example, log10100 means the exponent on 10 that results in 100. In other words, this logarithm is the answer to the question 10? = 100. Pretty clearly, the placeholder represented by ? is 2.
Every equation of the form logbx = y can be rewritten as an equivalent exponential equation by = x, and vice versa, with the only restrictions being that b > 0, and b[itex]\neq[/itex] 1, and x > 0.
