Are Expectation Values Measured for Coupled Photons from SPDC?
  • Context: Undergrad
  • Thread starter Thread starter emuc
    Coupled Photons
Entangled photons are generated through parametric down conversion (SPDC), specifically Type II SPDC, where one photon exhibits horizontal (H) polarization and the other vertical (V) polarization. In this scenario, photons that do not emerge from the intersection of the cone shells are distinguishable and thus not entangled, leading to independent polarization behavior. The discussion raises the question of whether expectation values have been measured for these distinguishable photons, highlighting a gap in current research.
  • Understanding of parametric down conversion (SPDC)
  • Knowledge of photon polarization (horizontal and vertical)
  • Familiarity with concepts of entanglement and distinguishability in quantum mechanics
  • Basic grasp of expectation values in quantum measurements
  • Research the principles of Type II parametric down conversion (SPDC)
  • Explore the implications of distinguishable photons on quantum entanglement
  • Investigate existing studies on expectation values for non-entangled photons
  • Learn about polarization measurement techniques in quantum optics
Quantum physicists, optical engineers, and researchers interested in the properties of entangled and distinguishable photons in quantum mechanics.
emuc
Entangled photons are generated, for example, by parametric down conversion (SPDC). The ordinary photon beam has polarization 0° and the extraordinary photon beam comes with the polarization 90°. Each photon leaves the source in a cone of light. Both cone shells intersect in two beams, which are thus each a mixture of horizontally and vertically polarized photons in equal share.
My question is how are photons related, which do not emerge on the line of intersection of the cone shells but are each clearly assigned to one of the two cone shells.
Does anybody know if this is measured already?
If the photons are distinguishable - as they would be in this case - they will not be entangled. One will be V, the other H. This is for what is called Type II SPDC. Not being entangled, they act independently as to polarization.
Do you know about measurements of expectation values for this case?
  • · Replies 20 ·
  • · Replies 58 ·
  • · Replies 19 ·
