Creating a parametric function for 17 related expressions in Mathematica
4 replies · 3K views · last reply
kaizen.moto
Hi there,
I have altogether 17 formulations or expressions which are repetitive and have link from each other.
My question is that how to make these formulation or expressions in a simpler form. In another word, how to make the codes or syntax become shorter due to these repetitive expressions.
Is there any better way to express all the 17 formulations in just one or two general codes but yet it works for all 17 expressions.
For instance:
the general expression is sub[r_]:=..... (1)
so if I want to substitute the value of any r, from 1 to 17, I got all the different 17 expressions as stated in the notebook attached.
Thank you in advance for any feedback.
Of course you can define
sub[1] = ...
instead of
sub1 = ...
and so on. If you're happy to use the current right-hand-sides of the definitions.
You don't need to have blanks (_) in the definition, i.e. you don't need sub[r_] := ...
But if you want to generate the right-hand-sides of the definition and use a single
sub[r_] := something goes here that depends on r
Then that might be a bit trickier. Do you have a clear mathematical formulation that generates all of the subs? I couldn't see anything too obvious from your code.
Sorry, I think I have confused you.
Actually, Iam trying to create a generic code of which I think looks like this sub[r_]:= ...
This desired generic code would be applicable to compute all the matrices as per r value.
Please see the revised notebook.
Thank you for any help.
wow..brilliant!. Eventhough, the notebook you sent was empty, I could not manage to open it. But, I have re typed the syntax from the pdf file and run the codes, its really works...you are truly very good at this...fantastic job..and I become more and more like Mathematica itself.
For your info, why sub[1] does not return the required expression. I mean when I run sub[1], it gives me sub[1]. However, the rests are working perfectly.
anway, can you please send the notebook again to my email add at kaizen.moto@yahoo.com, if you don't mind.
I really really apreciate your kind help..may God bless you..
