Current across resistor and inductor
5 replies · 24K views · last reply
verbose
I have a resistor and an inductor in series. The current across each is the same, correct? I want to know if I can use Ohm's Law to solve for current across the inductor if I know the Voltage and inductive reactance. Basically, does I = V/X_{L} ?
V = IR
I = V/R
does I = V/ X_{L} ?
??What do you mean by X_{L}? I can guess that V is the voltage drop, I the current and R the resistance. Is X_{L} the inductance? If so then, no, the voltage drop over an inductance is NOT given by the same equation as for a resistance. Surely you have that formula in your text?
X_{l}
by this i mean inductive reactance...sorry, it's tex syntax for X with L as a subscript. i have the habit of writing all my mathy stuff in latex syntax
Yes, [tex]I = \frac{V_L}{X_L}[/tex]
Notice that [tex]X_L[/tex] is dependent of the frequency of [tex]V_L[/tex]
V = IR
I = V/R
does I = V/ X_{L} ?
Forget the problem for a minute, first let's clear up that current isn't across anything. Current flows through and voltage is established across. Like fingers on a chalk board.:cry:
If those 2 elements are in series (the resistor and inductor) and connected to a voltage source, the current through all elements will be given by:
I = VS / (R + XL)
If the voltage you are talking about is the voltage across the inductor, then yes, the current through all elements will given by:
I = VL / XL
