Describing the sequence 0.3, 0.33, 0.333,
  • Thread starter rock.freak667
    Sequence
6 replies · 6K views · last reply
Homework Helper
Describe the following sequence
0.3,0.33,0.333,0.3333,0.33333,...
I tried to put the sequence as
[tex]\frac{3}{10},\frac{3}{10}+\frac{3}{100},\frac{3}{10}+\frac{3}{100}+\frac{3}{1000}+...[/tex]
But I didn't see anything happening there. Also I would hope the answer is convergent to [itex]\frac{1}{3}[/itex] since it looks like the number of 3's tend to infinity which would be the number of 3's in [itex]\frac{1}{3}[/itex]
It's 3 times the geometric series (1/10)^n starting at n=1, isn't it? The series sums to 1/9, doesn't it?
.3,.33,.333,.3333...
> 3 [.1+.11+.111+.1111...]
Solve in factors of 10 now ...
go ahead...
Hi rock.freak667! :smile:
You're only asked to describe the sequence.
In other words: find a formula A_n for the nth term.
For example, if the sequence is 1 8 27 64 …, then you describe it as {n³}.
Hint: As you point out, they're obviously getting closer to 1/3. So what is the difference between each term and 1/3? :smile:
well the differences are like this
1/3-0.3=0.0333...
1/3-0.33=0.00333...
1/3-0.333=0.000333...
So the differences run in a GP of first term a=0.0333... and common ratio r=0.1
But the sum to infinity = 0.0333../0.9 = 0.333...*1/9 = 1/3 * 1/9 = 1/27..Not 1/3 as I wanted.
rock.freak667 remember that [tex]\sum\frac{1}{10^{n}} = \frac{1}{1-\frac{1}{10}}[/tex] only when n goes from 0 to infinity. Is that the case in your example?
1/3-0.3=0.0333...
1/3-0.33=0.00333...
(remember, the question asks you to describe the sequence, and you haven't specifically done that yet.)
So 3An = 1 - what ?
And so ∑An = … ? :smile:
