Designing a Poka-Yoke for Flat Marks on Rocker Arm Bearing
  • Context: Automotive
  • Thread starter Thread starter billy_boy
    Designing
The discussion focuses on designing a Poka-Yoke system to detect flat marks on the outer diameter (OD) of rocker arm bearings, which are critical components in automotive applications. Quality control engineers are exploring the use of air gauges and machine vision systems for detection, while also considering displacement sensors, particularly optical types from manufacturers like Banner and Keyence. The root cause of the flat marks may stem from improper assembly lubrication or issues with the grinding process. Effective solutions require precise characterization of the defect and potentially involve customer feedback for further investigation.
  • Understanding of Poka-Yoke principles in quality control
  • Familiarity with displacement sensors, particularly optical types
  • Knowledge of grinding processes for automotive components
  • Experience with machine vision systems for quality assurance
  • Research the implementation of Poka-Yoke systems in manufacturing environments
  • Learn about optical displacement sensors and their applications in quality control
  • Investigate the impact of lubrication on bearing performance and failure modes
  • Explore machine vision technologies for detecting surface defects in high-volume production
Quality control engineers, manufacturing process engineers, and automotive component designers seeking to enhance product reliability and reduce defects in rocker arm bearings.
billy_boy
I am a quality control engineer in an automotive parts manufacturing company. One of our products is a rocker arm bearing which is essentially a cam follower. The OD and ID of the bearing is ground using CBN grinding wheels. The ID contains cylindrical rolling needles. Recently we have received a lot of customer complaints for flat marks on OD of the bearing. Can an air gauge be used to measure or detect these flat marks and also can a simple poka yoke be designed using the same.
Interesting, I hadn't seen that term before. Learn something new here at the PF every day...
https://en.wikipedia.org/wiki/Poka-yoke
Have you considered using machine vision to look at the finished parts to catch these problems?
What is a poka yoke? How is a bearing to function as a cam follower? is it acting as a roller follower? A picture might help explain your situation.
(See the Wikipedia link that I posted...) :smile:
that cam roller is basically a needle roller bearing
we manufacture 1.2 mil. of these in a month. we use a vision system for checking missing needles. it is difficult handling such large volumes. also vision systems cost a lot of money
Another vision system is also my guess for detecting the flats.
But you are the engineer in there. Characterise the symptom.
How wide? How deep? Can you see it by eye? Can you see it by camera? Is it one part randomly? Is it a bunch of parts in a row?
You can't ask yourself, let alone us, how to detect it until you know exactly what it is you want to detect
Hmm, first time I've heard the word/phrase/expression "poka-yoke" as well, either way...
So if I understand correctly, you need to ensure that the bearings are circular without any flat spots? It is difficult to get into any specifics without understanding the application in detail, however a displacement sensor monitoring the surface edge of the bearing while it is being ground may suit your needs.
I would vote for that approach. The sensor could be mechanical (potential problem due to speed & wear), optical (LASER displacement sensor or similar as supplied by industrial Manufacturers ( two that come to mind are Banner and Keyence)), electronic (capacitance distance sensor). Of the three, probably Optical is the best bet.
As for Root Cause, sounds like a bad bearing in one of your grinders.
Let us know what you find.
So the bearing is not rolling?
If this is say...a crower rocker arm, maybe the customers are using improper assembly lube which may cause the roller to not roll during that important first few minutes of operation.
Since oil is super slippery, it doesn't take much resistance to rolling to stop the rolling action without causing any damage to the needles...so the outside of the bearing glides on the oil film.
Once there is even a slight flat spot on the outside of the roller where it contacts the cam, it may stop rolling and now acts as a "pad type cam follower" instead of a bearing because oil is such a good lubricant that it allows the cam to turn against a stopped roller causing a flat spot to get worn eventually instead of causing damage that snowballs into galling and or catastrophic heating.
If a hydraulic "lifter" is employed, the bearing could stop turning every time there is oil pressure to keep it against the cam with any amount of pressure while a mechanical follower may allow turning when it's not under pressure of opening the valve.
In stock factory usage, you have less chance of the wrong lubricant being used but in the aftermarket horsepower world, every guy has his own recipe and many are just wrong.
If a customer can send back the rocker arm and the camshaft, you could install it in an engine and just watch the roller to see if it's stopping and you should easily hear the "thumping" if it is.
Maybe a customer can make the observation himself and let you know what he's seeing.
Can you post a picture of the product you make and the defects you encounter?
can these detect displacements in microns??
