Determine closed expression for b(n) without recursion or product
  • Thread starter Thread starter maxmilian
    Closed Expression
15 replies · 3K views
maxmilian
determine a closed expression for b(n), given
b(0) = 3
b(n+1) = 2+[itex]\prod[/itex] (k=0 to n) * b(k) , n >= 0 , without using recursion og or the product given by [itex]\prod[/itex].
I want to start out by b(n+1) -1 = (b(n)-1)^2 for n >= 0 , but I am not sure.
kind regards
Maxmilian
b(0) = 3
kind regards
Maxmilian
What does the word "wanna" mean?
Have you tried writing out the first few b(k), to see if there is any discernible pattern?
RGV
oh sry, want to is my street slang for "want to".
And no I havent
The usual way to tackle this sort of problem is to write out the first few terms of the sequence, discern the pattern, then prove it by induction.
Hint: think in terms of powers of 2 plus a little something.
Thx for your reply.
so for n = 1 , I am getting ;
2 + b(0) *b(1) = 2 + 3 * b(1)
for n = 2 ;
2 + 3 * b(1) * b(2)
edit: could 2+3*b(n)! be a solution to the pattern ?
Can anyone give me a hint for what I should do next ?
any help is still appreciated
maxmilian said:
Thx for your reply.
for n = 2 ;
2 + 3 * b(1) * b(2)
No.
b(n+1) = 2 + ∏(k from 0 to n) b(k)
So b(1) = 2 + ∏(k from 0 to 0)b(k) = 2 + b(0) = 2 + 3 = 5.
Can you now work out b(2), b(3), b(4) and b(5)? Try and see the pattern, then I (or someone else) can guide you through the induction if you still have problems.
Curious3141 said:
No.
then
b(2) = 2 + ∏(k from 0 to 1)b(k) = 2 + b(0)*b(1) = 2 + 3*b(1)
b(3) = 2 + ∏(k from 0 to 2)b(k) = 2 + b(0)*b(1)*b(2) = 2 + 3*b(1)*b(2)
b(4) = 2 + ∏(k from 0 to 3)b(k) = 2 + b(0)*b(1)*b(2)*b(3) = 2 + 3*b(1)*b(2)*b(3)
b(5) = 2 + ∏(k from 0 to 4)b(k) = 2 + b(0)*b(1)*b(2)*b(3)*b(4) = 2 + 3*b(1)*b(2)*b(3)*b(4)
right ?
maxmilian said:
then
right ?
Yes, but calculate them (get the final numbers).
You should be able to make out the pattern clearly by b(4). b(5) is a little large, so you may not want to bother with that.
right.
b(2) = 17
b(3) = 257
b(4) = 65537
as far as a pattern goes for b(n) , I think I have a good idea (Fermet)
maxmilian said:
right.
b(2) = 17
b(3) = 257
b(4) = 65537
Yes, they are Fermat numbers. Now prove it by induction.
is recursion not a part of induction ?
I might have misunderstood the "determine the closed expression - without using recursion" wrong. but if I wanted to prove it by induction. I would;
1. prove the basis ;
b(0)=2^(2^0) +1 = 3 , true , basis proven.
2. prove inductionstep
b(n) -> b(n+1)
b(n) = 2^(2^n) +1 -> b(n+1)=2^(2^n+1) +1
b(1) = 2^(2^1) +1 = 5 -> b(1+1)2^(2^1+1)+1 = 17
both n and n+1 is true, so I have proven it for both n and n+1 - right ?
What I mean is that you need to prove the closed form expression by mathematical induction. You've only inferred a pattern by observation, but you haven't rigorously proven it.
Of course, you need to use the recursive relation in your proof. But it needs to be a formal inductive proof, starting with an inductive hypothesis.
b(n) -> b(n+1)
Let P(n) be the proposition that b(n) = 2^(2^n) + 1. This is the inductive hypothesis which you start by assuming.
From this, you need to establish that P(n+1) is true, i.e. that b(n+1) = 2^(2^(n+1)) + 1.
This needs to be an algebraic (symbolic) proof. Just verifying it for certain numerical n's is not sufficient.
right.
so I start with my hypothesis, then prove basis , then assume P(n) is true , then last prove P(n+1) is true. How do I prove P(n+1) is true?
maxmilian said:
right.
Wanted to reply to this earlier, but a lot of things came up.
So assume P(n) is true. Hence you can write down b(n) = 2^(2^n) + 1
Now you have to use this given relation: b(n+1) = 2 + ∏(from 0 to n) b(k)
to somehow arrive at b(n+1) = 2^(2^(n+1)) + 1
which would establish P(n+1).
Here's a hint:
∏(from 0 to n) b(k) = b(n) * ∏(from 0 to (n-1)) b(k)
and
b(n) = 2 + ∏(from 0 to (n-1)) b(k),
so ∏(from 0 to (n-1)) b(k) = b(n) - 2
Can you put all that together and do the remaining algebra to prove the result?
