Determining the Highest pH for Acid Solutions
  • Thread starter Thread starter sp3sp2sp
    Ph
The discussion clarifies the meaning of "in acid" in the context of a homework question regarding pH levels of various acid solutions, indicating that it refers to a 0.10 M concentration of acid in water. It explains that while the analytical concentration is 0.10 M, the actual concentration of undissociated acid will be lower due to partial dissociation. The conversation highlights two examples: acetic acid, a weak monoprotic acid, and oxalic acid, a diprotic acid, noting that oxalic acid has a higher acidity and thus a lower pH compared to acetic acid. The relationship between pKa values and pH is emphasized, with higher pKa indicating a higher pH and lower acidity. Ultimately, acetic acid will have a higher pH than oxalic acid when both are at the same molarity.
sp3sp2sp
I am just a little confused about how the question is worded. It asks:
Which of the following solutions would have the highest pH? Assume that they are all
0.10 M in acid at 25 C
. The acid is followed by its Ka value.
the bolded is what I don't understand. I don't know what they mean by "in acid" ? thanks for any help
That means the analytical cocentration of the acid is 0.10M. That is, the solution is the result of dissolving 0.1 moles of the acid in 1L of water. Actually, the acid will be partly dissociated, so the true concentration of the acid form will be less than 0.1 M. So if you had 0.1 moles of acetic acid (AcOH) in water, you would have some undissociated AcOH and some dissociated H+ and AcO-. The total concentration of AcOH and AcO- would be 0.1 M, and that is what the question refers to.
The values for pKa come from the acids' Ka values. The "p" part of the constant means, "negative logarithm of...".
Two specific examples:
Acetic Acid, Ka=1.8*10^(-5), pKa=4.756, weak monoprotic acid
Oxalic Acid, Ka1=5.37*10^(-2), pKa1=1.27, diprotic acid, not so weak compared to Acetic
Each if dissolved to the same molarity will show less acidic for Acetic than for Oxalic; Meaning LOWER pH for Acetic than for the stronger Oxalic.
The Acetic Acid solution will have the higher pH, of the two solutions. You can make your predictions using the pKa values or using the Ka values. Higher pKa, higher pH of the acid in solution, lower acidity in solution
  • · Replies 16 ·
