Difference between curl and divergence of vector fields vs fixed functions
Blkmage
http://img818.imageshack.us/f/screenshot20110423at733.png/
http://img856.imageshack.us/f/screenshot20110423at733.png/
If it'll help you guys help me understand this, here are the solutions:
http://img828.imageshack.us/f/screenshot20110423at752.png/
[tex]\text{curl}\bold{F} = \nabla \times \bold{F}[/tex]
[tex]\text{div}(\bold{F}) = \nabla \cdot \bold{F}[/tex]
My problem is that I don't understand what is meant by a "fixed, but arbitrary function" or a "fixed, but arbitrary vector field." Is a fixed function one that is constant? ie [tex]g(x,y,z) = 2[/tex] Is a fixed vector fixed a constant one, like [tex]\bold{F}(x,y,z) = 2\hat{i} + 3\hat{j} - 5\hat{k}[/tex]?
My problem is that I'm not really understanding the nature of these vector operators. I have the solution and it says:
[tex]\text{curl} \nabla g[/tex] is a constant vector whereas
[tex]\text{curl} \bold{F}[/tex] is a vector field
How is it possible that they are not both vector fields. Same with this:
[tex]\text{div} (\text{curl} \bold{F})[/tex] is a constant scalar whereas
[tex]\text{div} (\bold{v} \times \bold{F})[/tex] is a scalar function...
How are these not both scalar functions?
=No, a "fixed" function is just a "given" one- for the purposes of this problem you are talking about a specific ("fixed") function.
For g a scalar function, you can say more than just that "[itex]curl \nabla g[/itex] vis a constant function"- it is a very specific constant!
If g(x,y,z) is a real valued function, then
[tex]\nabla g= \frac{\partial g}{\partial x}\vec{i}+ \frac{\partial g}{\partial y}\vec{j}+ \frac{\partial g}{\partial z}\vec{k}[/tex].
And so
[tex]curl \nabla g= \nabla\times\nabla g= \left|\begin{array}{ccc}\vec{i} & \vec{j} & \vec{k} \\ \frac{\partial }{\partial x} & \frac{\partial}{\partial y} & \frac{\partial}{\partial z} \\ \frac{\partial g}{\partial x} & \frac{\partial g}{\partial y} & \frac{\partial g}{\partial z}\end{array}\right|[/tex]
Now what is that?
(Assuming that g has continuous second derivatives.)
OH. I completely forgot my rules. The curl of a gradient is a the zero vector and the divergence of the curl is the scalar 0. Thanks.
Also, for the very last integral, does that not not exist because [tex]d\bold{s}[/tex] denotes a line integral, but since there are two integral symbols, it doesn't mean anything? Or is it because there is not dot product between [tex]\nabla g[/tex] and the differential [tex]d\bold{s}[/tex]?
It should be dS, the differential of surface area, not ds, the differential or arc length.
