Undergrad What are the recommended tests for comparing two sets of data?
  • Thread starter Thread starter VVS2000
    Testing
To compare two sets of data, specifically observed and expected values of focal length, the Chi-squared goodness of fit test and linear regression are recommended. The Chi-squared test is suitable for assessing how well the observed data fits the expected model, while linear regression can analyze the relationship between the two sets if a linear model is applicable. It's important to consider the uncertainties associated with the data, as they can influence the results. The sum of square residuals can also provide a numerical measure of the differences between the two datasets. Overall, these methods can effectively quantify the differences and fit of the observed data against the expected values.
VVS2000
So I have two columns of data, One containing experimental values and the other having expected values. So I read that chi-squared test and Anova Tests can be used to compare two set of data. My main aim is to quantitatively know how different these two sets of data are, so are these two tests enough or is there any other tests that you would suggest?
The standard measure of distance would be the sum of square residuals. However, I am not sure what you are asking has real meaning as stated.
As I understand your statement, you don’t have two sets of data, you have one set of data and a model. Any set of data can plausibly come from any model given sufficiently uncertain measurements. So just asking about the sum of square residuals doesn’t say much.
If your model has any free parameters then you can meaningfully ask which parameters minimize the residuals. Or if you have two competing models you can ask which model minimizes the residuals. Or if you can predict the expected uncertainty in your measurements, then you can determine how likely the data is under the model.
Likes WWGD, VVS2000 and FactChecker
Asking "how different" your data is from the expected values of a model is a vague question.
Are you asking how likely (probability) such data might fit the model like that (or worse)? The Chi-squared goodness of fit test is well suited for that.
Are you asking for some numerical measure of how great the differences are? The sum-squared-errors total is well suited for that.
Likes VVS2000
ok sorry for not being clear. I have two sets of data. One column contains Observed or experimental focal length of a lens at different heights from the axis. The Other column contains the expected or theoretical value of focal length. so yeah I want to quantitatively know different these two sets of data are given the uncertainty and errors in the observed data
Does this column have uncertainty associated with it?
Likes WWGD
yes, but all values have the same uncertainty
Two possibilities are Chi-Squared goodness of fit, and linear regression. The first one is very general. It requires that the data be combined into categories. The second one requires that the model of the variable of interest is a linear function of the other variables.
