Difficult geometries - Casimir Effect
  • Context: Graduate
  • Thread starter Thread starter Kruger
    Casimir effect
The discussion revolves around the Casimir Effect, particularly focusing on the geometrical configurations involved, such as the interaction between electromagnetic oscillators in various shapes (plates and spheres) and the implications for standing waves. Participants explore theoretical aspects, mathematical reasoning, and conceptual clarifications related to the effect.
  • Some participants question whether only one electromagnetic oscillator can exist in the ground state within a given geometry, suggesting this may not be true.
  • There is uncertainty about the relevance and physical interpretation of diagrams related to the Casimir Effect, with requests for clarification on their context.
  • Participants discuss the nature of standing waves between plates and how these might be represented in different geometrical configurations, such as between a circle and a plate.
  • One participant proposes that the oscillations of the electromagnetic field can build standing waves between both plates and a sphere, raising questions about the physical relevance of using a sphere instead of a plate.
  • Another participant introduces the concept of adiabatic transfer of energy between different modes as the configuration changes, suggesting that energy can be concentrated in specific harmonics under certain conditions.
  • There is a query about whether a topological logic exists to determine the attraction or repulsion between different configurations of Casimir objects.
Participants express various viewpoints and hypotheses regarding the geometrical configurations and implications of the Casimir Effect, with no consensus reached on the validity of specific models or interpretations.
Participants highlight limitations in understanding the implications of changing geometries on oscillations and standing waves, as well as the need for further clarification on the physical relevance of certain configurations.
Kruger
I really need your help.
Is there in the green field only place for one electromagnetic "oscillator" in ground state (the red one)? (Because these oscillators have to be at an angle of 90 degrees on the walls). I think this cannot be true.
nobody knows?
Please, I wonder if you know.
What does this picture represent ? Is it a feynmann diagram that expresses a loop or is it referring to world lines ? Please, illustrate its context. Where did you get it from ? In what chapter has it been given?
It makes no sense to me
marlon
Ok, first please visit this picture with the wave between the plates:
http://images.google.ch/imgres?imgu...ages?q=casimir+effect&svnum=10&hl=de&lr=&sa=N
Now, you see there are standing waves (oscillations) between the plates. The thing what I try is to draw such oscillations between a circle and a plate.
And I don't really know how to draw this oscillations (between circle and plate), I mean in case of the Casimir-Effect they have to be at an angle of 90 degree at the wall, other oscillations are forbidden. Do you see?
I thank the person or people who can help me.
Err, what is the point using a circle and a plate ? What is the physical relevance ?
What you can do is this : the circle itself can be seen as an infinitesimal sequence of little lines. One can then treat each line and the other plate. Ofcourse, when both plates are not parallel then no standing waves are possible so basically there is only one contribution, ie the one i mentioned above with two parallel plates
marlon
The relevance is to calculate the Casimir Force between sphere and plate that comes from the zero point energy of the electromagnetic field. The oscillations of the electromagnetic field are in their lowest possivle energy state, E=h(bar)omega/2, if they are in vacuum state. These oscillations can just build standing waves between two plates and between a sphere and a plate. You see?
Thanks marlon.
Thanks marlon.
But why a sphere and a plate ?
I mean, the reason we use the two plates is just to illustrate the existence of this Casimir force. The distance between the two plates selects only certain waves that can exist in between them...So why would you want to replace one plate by a sphere if you take this reasoning into account ?
marlon
Why not :smile: . I calculated the force between two plates, its quite easy. Now, I wanted to make some connections between various geometries of the Casimir-effect.
Another question is the following:
Between a plate there is one electromagnetic oscillation with wavenumber k, such that we have k=pi/L where L is the distance between the plates. This is one oscillation I picked out of the whole set of oscillations. The angular velocity omega of this oscillation has to bi: w=c*pi/L at time t1. Now, the plates will be pushed together (Casimir- Force). Can we then just say, that at time t2 where the new distance between the plates is smaller then L, the angular velocity of that oscillation has just changed or must we say this oscillation is "destroyed"?
In my opinion, your last question address the issue of adiabatic transfer of energy between the first set of modes to the second. If you have all of your energy concentrated, for exemple, in the third Harmonic of the first set of modes...if you start changing the configuration slowly enough to maintain the adiabatic regime, then you will end up with all the energy concetrated in the third harmonic of the sencond set of modes. If you make this transition out of adiabatic regime, energy from the first set of modes are arraged statistically among the frequencies of the sencond mode.
Regarding Casimir Effect, I wonder if is there anyone who had discovered a kind of topological logic in terms of which one can easily decide if a certain configuration of Casimir objects will yield attraction or repulsion.
  • · Replies 46 ·
  • · Replies 46 ·
  • · Replies 17 ·
