Discrepancy in Co-Moving Charges Magnetic Force?
The discussion centers on the discrepancy between the magnetic field calculated using the Biot-Savart Law and the relativistic transformation of electric and magnetic fields for two identical charges moving together. The charges, each with charge q and speed v, are separated by a distance r. The expected magnetic field B' derived from relativistic transformations does not match the magnetic field B1 calculated using the Biot-Savart Law, indicating that the latter is an approximation valid only at non-relativistic speeds. The conversation highlights the need for a relativistic form of the Biot-Savart Law and references the Liénard-Wiechert potentials as a more accurate framework for understanding electromagnetic interactions at relativistic speeds.
  • Understanding of the Biot-Savart Law and its applications in electromagnetism.
  • Familiarity with Maxwell's equations and their implications in classical electromagnetism.
  • Knowledge of relativistic transformations of electric and magnetic fields.
  • Basic concepts of electric fields (E-fields) and magnetic fields (B-fields) in physics.
  • Research the Liénard-Wiechert potentials and their derivation from Maxwell's equations.
  • Study the relativistic transformations of electric and magnetic fields in detail.
  • Explore the implications of the Biot-Savart Law in both classical and relativistic contexts.
  • Investigate the conditions under which the Biot-Savart Law is applicable and its limitations.
Physicists, electrical engineers, and students studying electromagnetism, particularly those interested in the interplay between classical and relativistic physics.
  • #31
greswd said:
Why does this factor not lead to a different B field? If the proof is complex maybe you can just post a link, that's ok.
##\frac{1-v^2/c^2}{(1-v^2\sin^2\theta/c^2)^{3/2}}##
The easiest way to see that is to just look at the retarded potentials. In the retarded potentials A depends only on J and B depends only on A. So if J is identical then B is also identical.
  • #32
Wow that's so counter-intuitive. :)) I think almost anyone looking at the problem at first glance would assume that the B-field would be affected.
Does this mean that the relativistic changes within the charge distribution somehow offset each other?
  • #33
I don't know what you mean by that. Aren't you dealing with a single frame? So what relativistic changes are you talking about in a single frame?
  • #34
The ##\frac{1-v^2/c^2}{(1-v^2\sin^2\theta/c^2)^{3/2}}## factor getting larger and larger as the speeds of the charge distribution increase.
The increase in speed is matched by a decrease in charge density, as mentioned in #28, so that J remains unchanged.
  • #35
I am not exactly sure what that factor is or where it comes from (in terms of assumptions in the derivation). If it is for a point charge then you cannot increase v without increasing J also.
  • #36
I first mentioned it in #16:
greswd said:
here is the formula I wanted to post:
## \mathbf{B} =\frac{\mu_0 q}{4\pi}\frac{1-v^2/c^2}{(1-v^2\sin^2\theta/c^2)^{3/2}} \mathbf{v} \times \frac{\mathbf{\hat r'}}{|\mathbf r'|^2}##
from https://en.wikipedia.org/wiki/Biot–Savart_law#Point_charge_at_constant_velocity
Is it considered relativistically accurate?
I thought you had acknowledged it in #31 as well:
A continuous charge distribution can be approximated by a 'cloud' or 'fine mist' of point charges.
I wrote:
greswd said:
Imagine two fields of charge. One has a high charge density but slow speeds. One has very low charge density but high speeds, relativistic speeds.
Therefore both have the same J fields, numerically speaking.
I am talking about the comparison of two different scenarios, one with dense charge and slow speeds, and another with less dense charge and faster speeds.
  • #37
I was just quoting your post.
You can get a lot of incorrect intuition that way. For example, you might conclude that you should get synchrotron radiation from a DC current loop.
greswd said:
I am talking about two different scenarios, one with dense charge and slow speeds, and another with less dense charge and faster speeds.
If J is the same in the two different scenarios then B is the same in the two different scenarios.
  • #38
haha, that's interesting, why can't we get sync radiation from a current loop? Isn't the current in a loop also made of moving charged particles?
Yes, you told me that already. So I asked if this was due to the relativistic effects offsetting each other.
I asked because B being the same in both scenarios is so counter-intuitive to me.
  • #39
Because J is not a function of time for a DC current loop so there is no radiation.
Which is precisely why thinking of a continuous current distribution as a collection of charged point particles can give you faulty intuition.
Understood. Unfortunately, what you mean by "relativistic effects" here is a term from an equation for point charges, so it doesn't readily apply for continuous charge distributions.
Of course, it is possible to go from one to the other through careful integration, but it is not trivial and the proof from continuous distributions is so easy that I don't see the point in going through that exercise.
  • #40
Do you know of any webpage that shows how to go from one to the other?I found this article about synchrotron radiation: http://puhep1.princeton.edu/~kirkmcd/examples/steadycurrent.pdf
Kirk T. McDonald said:
If the steady current were a continuous DC current, all of its multipole moments would be constant, and we would expect no radiation.1 For a current consisting of electrons, it must be that the radiation is canceled by destructive interference between the radiation fields of the large number N of electrons that make up the steady current.
I sound like a broken record; is it useful to think of the relativistic effects offsetting one another just like the destructive interference between the radiation fields of a continuous steady current?
  • #41
Not for this specific problem, no. But you can get a general idea of the approach in calculus based discussions of Newton's shell theorem.
The comment about destructive interference is perfect.
I can't answer this for the reason described above.
  • #42
which reason?
  • #43
greswd said:
which reason?
Last two paragraphs of post 39
  • #44
so its because the proof is not easy? ok.
  • #45
Well, the proof which I gave is very easy, it just doesn't involve the terms you are choosing to focus on. Putting those terms in would be hard and would serve no other purpose, so I am not inclined to do it nor do I know of anyone else who was. You are certainly welcome to do it if it feels important to you.
  • #46
Yeah, no worries. You've already explained how it works conceptually, which has been enough to answer my question(s).
It is actually important to me, but since its so hard I'll save it for another day.
Thanks for all the help rendered for this thread.:thumbup::sun:
  • · Replies 16 ·
  • · Replies 28 ·
  • · Replies 20 ·
  • · Replies 30 ·
  • · Replies 24 ·
