Does Intersection Distribute Over Subset in Set Theory?
20 replies · 3K views · last reply
marovan
$$ A \subset B \Rightarrow A \cap C \subset B \cap C $$
2. Homework Equations [/B]
$$ A \subset B \Leftrightarrow A \cup B \subset B$$
$$ A \cap C \Leftrightarrow A \cap C \subset A \wedge A \cap C \subset C$$
For sets A and C
$$A \cap C \Rightarrow A \cap C \subset A $$
Likewise for sets B and C
$$B \cap C \Rightarrow B \cap C \subset B$$
Therefore
$$A \subset B \Rightarrow A \cap C \subset B \cap C $$
I don't know if I'm completely off the map
I'm sorry..
I have to proof the first statement.
I have attempted at a proof, but I don't know if it's the right way to do so. I'm asking for a little guidance
For sets A and C
This makes no sense. I think what you mean is simply:
$$A \cap C \subset A $$
As an aside, can you prove this?
Same here.
Therefore
The conclusion certainly doesn't follow.
To help you prove this properly, the first question is: can you state (formally) the definition for one set to be a subset of another? In this case $$ A \subset B$$
Can you state formally what that means?
All right
$$ A \subset B \Leftrightarrow (x \in A \Rightarrow x \in B) $$
As for A∩C⊂A
$$ A \cap C \Leftrightarrow (x \in A and x \in C) $$
$$ If x \in C then x \in A \cap C \Leftrightarrow x \in A $$
Therefore, since A ∩ C ⊂ A and likewise for B ∩ C then A ∩ C ⊂ B ∩ C
marovan said:
All right
That's right. You should use this to try to prove the original proposition.
marovan said:
As for A∩C⊂A
That doesn't make sense. I think you mean:
$$ x \in A \cap C \Leftrightarrow (x \in A \ and \ x \in C) $$
You must be more careful how you use these symbols.
One final point. To prove something it's often best to start the proof with what you have, so I would start with:
Let ##A \subset B##
yes, it is okay. The proof is correct.
And, if A is always a subset of A, and so does A intersection C a subset of C.
It's not.
This sentence doesn't make sense.
I can't follow your reasoning here. You want to prove that if A⊂B, then A ∩ C ⊂ B ∩ C. So you need to start by stating that you're assuming that A⊂B. Then, since what you want to prove now is that every element of A ∩ C is an element of B ∩ C, the straightforward way to continue is with something like "let x be an arbitrary element of A ∩ C". (It's OK to just say "Let ##x\in A\cap C##). Then you explain how you can be sure that x is an element of B ∩ C.
You should use a direct proof to show ##A \subseteq B \Rightarrow A \cap C \subseteq B \cap C##.
Start by saying "If ##A \subseteq B##, then ##\forall x, \space x \in A \Rightarrow x \in B##".
Now choose an arbitrary ##y \in A \cap C##. Then ##y \in A## and ##y \in C##.
You know if ##y \in A##, then ##y \in B## because of the starting statement.
Now we know ##y \in B## and ##y \in C## because of the two previous statements, so you only have one conclusion to make.
Why won't?
Like, let x∈A
And A⊂C
Then, x may or may not belong to C.
If x belongs to C, then x∈(A∩C)
If x does not belong to C, then Φ∈(A∩C)
Here Φ= empty set.
Whatever be the case, (A∩C) becomes
a subset of C.
Well, it's not how you prove it. It's if you can prove it. In class ten, I did this proof the same way.
fireflies said:
Why won't?
Why won't what?
fireflies said:
Like, let x∈A
And A⊂C
Here Φ= empty set.
The empty set is a subset of every set, whether or not x ∈ C. It's silly to conclude a statement that is always true.
a subset of C.
The technical term for this kind of argument is "arm waving."
Mark44 said:
Why won't what?
Why won't it make sense?
I know, but since they saying that it's
unreasonable that A∩C is a subset of C (which is also always true), so, I described it elaborately.
I don't understand what you meant by arm-waving.
Am I any wrong here?
fireflies said:
Like, let x∈A
And A⊂C
x certainly belongs to C, since you assumed both that x is an element of A, and that every element of A is an element of C.
Here Φ= empty set.
Here's an empty set symbol that you can copy and paste: ∅
You can also find it by clicking the ∑ symbol above the field where you type your post.
Why would ∅ be an element of A∩C?
a subset of C.
If you want to prove that A∩C is a subset of C, this is how you do it: Let x be an arbitrary element of A∩C. Since x is an element of A∩C, it's an element of A and an element of C. In particular, it's an element of C.
Alternatively you just write down these implications along with a comment that says that they hold for all x:
##x\in A\cap C\Rightarrow \left(x\in A\text{ and }x\in C\right)\Rightarrow x\in C##.
Well, the statement is still true if you don't consider A is a subset of C.
fireflies said:
And A⊂C
I think I would rather exclude this part. It is a mistake, other part is okay.
All right. But the same thing comes that this statement is true. That makes the proof correct too.
ma [QUOTE="Fredrik said:
It's not.
Yes, it's actually not.
marovan said:
Therefore
It doesn't come.
Marovan's argument in posts #1 and #5 appears to be that since ##A\cap C\subseteq A\subseteq B## and ##B\cap C\subseteq B##, we have ##A\cap C\subseteq B\cap C##. To see that this line of reasoning doesn't work, try replacing ##A\cap C## and ##B\cap C## with two arbitrary sets. Does the following implication hold for all E,F?
If ##E\subseteq A\subseteq B## and ##F\subseteq B##, then ##E\subseteq F##​
It does not. Consider e.g. E={1,2}, A=B={1,2,3}, F={2,3}.
Reading anything past post #9 has fried my logic processor.
I don't see how anything fireflies has said can hold any merit.
I think I should say sorry for that.
I put more emphasis on the subset statements of the OP than the final conclusion. The final conclusion is, anyways, not correct.
