Does limit 1/x at zero equal infinity? How it is accepted in High School now?
  • Thread starter Thread starter MichPod
    Limit
15 replies · 12K views
MichPod
Hello. Per what I was taught in my youth, ##\lim_{x \to 0}\frac{1}{x}=\infty##
Is it in agreement with how the calculus is taught today in the High Schools and Universities of US/Canada specifically?
Per what my son says, that limit should be considered as undefined because
##\lim_{x \to 0^+}\frac{1}{x}=+\infty##
and
##\lim_{x \to 0^-}\frac{1}{x}=-\infty##
and as these infinities have different signs, the general limit does not exist (even if expressed as "infinity").
Disclaimer: I understand that my question is about the conventions and about how the math is taught, not about the math itself.
Are you saying that in your youth you were taught that ##\lim_{x \to 0}(\pm\frac{1}{x})=\infty##?
In my youth I was taught that ##\lim_{x \to 0}(\pm\frac{1}{x})=\pm \infty.##
Furthermore, if I saw ##\lim_{x \to 0}(\frac{1}{x})##, I would assume an implicit ##+## sign in front of the fraction. The fact that we are taking a limit does not invalidate that common assumption. I think your son is nitpicking.
No. I said that I was taught that ##\lim_{x \to 0}\frac{1}{x}=\infty##
I.e. no plus/minus sign before ##\frac{1}{x}##
And in the other two lines
and
I meant one-sided limits, a right-hand and a left-hand limits, i.e.
##\lim_{x \to (0^+)}\frac{1}{x}=+\infty##
and
##\lim_{x \to (0^-)}\frac{1}{x}=-\infty##
I simply asked to understand how the mainstream High School and University textbooks treat this limit. I.e. what should be the right answer.
The first line in your quoted statement says that if ##x## is on the positive x-axis and approaches zero right to left, the fraction ##\frac{1}{x}## goes to plus infinity.
The second line in your quoted statement says that if ##x## is on the negative x-axis and approaches zero left to right, the fraction ##\frac{1}{x}## goes to minus infinity.
Now what about the bone of contention, ##\lim_{x \to 0}\frac{1}{x}=\infty##? If we go by the convention that ##x## without a sign means some distance from the origin on the positive axis, then the statement is correct. If we understand that ##x## is just a placeholder and can have positive or negative values, then your son is correct and the statement is ambiguous.
However, limiting expressions such as this are not standalone and devoid of context. When we take a limit, we know on which side of the axis we are and how we approach the origin. Thus, we know whether the first or second line in your statement above is the case.
I don't think that what you (or your son) say is wrong. It's just dotting all the i's and crossing all the t's when everybody knows what is meant.
You are using the projectively extended real line and your son is using the extended real number line.
You may like to consider one-sided limits explaining why the central limit doesn't exist using the latter set but it does using the former.
The latter set is much more relevant today because:
https://en.wikipedia.org/wiki/Signed_zero said:
The IEEE 754 standard for floating-point arithmetic (presently used by most computers and programming languages that support floating-point numbers) requires both +0 and −0. Real arithmetic with signed zeros can be considered a variant of the extended real number line such that 1/−0 = − and 1/+0 = +∞; division is only undefined for ±0/±0 and ±∞/±∞.
Well, that could be treated that way, but practically in the approach I was taught, having 1/x limit equal to infinity just meant that the absolute value of ##\frac{1}{x}## may be made arbitrary large in a small enough neighborhood of x=0. That is, in that approach it was not the case that there was only one "infinity", but the following three equations had a defined (and different) meaning:
##\lim_{x \to 0}f(x)=\infty##
##\lim_{x \to 0}f(x)=-\infty##
##\lim_{x \to 0}f(x)=+\infty##
Nevertheless, I am not looking to see who is right here, me or my son or which approach is more relevant. I simply wanted to understand what is ##\lim_{x \to 0}\frac{1}{x}## as per US/Canada mainstream textbooks.
According to Wolfram, it doesn't exist as stated here:
https://en.wikipedia.org/wiki/Limit_of_a_function#Existence_and_one-sided_limits said:
Alternatively, ##x## may approach ##p## from above (right) or below (left), in which case the limits may be written as
$$\lim _{x\to p^{+}}f(x)=L$$
or
$$\lim _{x\to p^{-}}f(x)=L$$
respectively. If these limits exist at ##p## and are equal there, then this can be referred to as the limit of ##f(x)## at ##p##. If the one-sided limits exist at ##p##, but are unequal, then there is no limit at ##p## (i.e., the limit at ##p## does not exist). If either one-sided limit does not exist at ##p##, then the limit at ##p## also does not exist.
Your son is correct and that is how it should have always been taught. The limits from above and below 0 are very different.
If x approaches 0 from below, the values become large negative numbers. From above they become very large positive numbers. So that should not be called a limit.
and
Correct.
It's not just a matter of convention. For values of x very near 0, the negative and positive values of 1/x are not close to each other. So saying that it has a limit would be misleading as to the behavior of 1/x near x=0.
Wolfram is a very good reference, thank you!
Your quote from Wikipedia is probably not so good as it speaks about a limit equal a particular value, while limits which are equal to infinity are special cases and normally need even a separate definition of what they are. Yet at the same page it mentioned that 1/x has no limit on the extended real line, so, again, that shows to me that 1/x having no limit is a very acceptable in practice point of view. Thank you again!
If you plot ##1/x## in the neighborhood of 0, it should be clear that the limit ##x \rightarrow 0## is undefined.
Amen.
##\lim_{x \to 0}\frac 1 x## does not exist; i.e., the limit is undefined.
Exactly.
The usual notation is ##\lim_{x \to 0^+}## and ##\lim_{x \to 0^-}## to indicate whether the limit is from the right or left, respectively.
This doesn't make sense. The expressions ##\frac 1 x## and ##+\frac 1 x## (or ##\frac {+1}x##) are exactly the same.
Not at all. The son is correct. Perhaps the OP is misremembering what he learned years ago.
Or perhaps I am misremembering what I didn't learn many years ago. :frown:
  • Haha
