Does the *First Postulate* Prohibit different time dilations?
53 replies · 6K views
Physics_Teacher
For example, Brian Greene says in The Elegant Universe regarding special relativity and train moving with constant velocity relative to platform: By the principle of relativity or first postulate, "there is no way for an observer on this train to detect any influence of the train's motion. But if the light clock and Rolex were to fall out of synchronization, this would be a noticeable influence indeed. [So] the Rolex must slow down in exactly the same way that the light clock does."
The first postulate states that the laws of physics are the same in all inertial frames of reference. The train passenger can look out the window and conclude that train is moving relative to platform (noting distance changing). The first postulate is from Galilean relativity. It does imply that one cannot have experiments that detect absolute motion. But in arguments, such as in above book, is it not being extended to imply that one cannot have experiments that detect Relative motion? We know from experience that we CAN detect Relative motion by multiple methods, so why could such non-matching clocks not be just another method.
Note: I am asking ONLY in reference to *First Postulate being violated* if different clocks gave different time dilation, and use of THAT reasoning ALONE to conclude that all clocks must show the same time dilation. (I am aware of the Lorentz transformations and their derivation which show that all clocks have to give same time dilation).
If such non-matching clocks happened (and of course they never do) that would lead to a measurement of absolute motion, not relative motion. We could change our speed until we found some speed at which the mismatch disappeared and the light clock and the Rolex both ticked at the same rate. That would be a measurement of absolute speed: as long as the two clocks did not match we would know that we were in motion, without having to say what that motion was relative to.
No. The wristwatch and the light clock are not in relative motion - in fact, that is the point of the argument. The point is that if different clocks that are at relative rest would get different time dilation, then you would be able to detect an absolute motion. If you set up a device such that you place the wristwatch at one of the mirrors of a light clock and check the proper time difference it reads for consecutive bounces for the light clock, the final measurement you make must be the same regardless of whether you make the measurement in the rest frame or any other frame.
Two clocks in train match when train is NOT moving Relative to platform but mismatch when train is moving relative to platform. Why would mismatch disappearing be a measure of absolute speed? It would only mean that the frame we have found is one that is also NOT moving Relative to the platform.
It would single out the platform frame as being a special frame (ie, the frame where clocks match), which violates the principle of relativity.
The issue was the claim, such as in Brian Greene's book, that principle of relativity prohibits different clock mechanisms from having different time dilation. If different clock mechanisms had different time dilation then inertial frames where two clocks were manufactured (to be in sync) would be "special frames" to those clocks. In calling that a violation have we not moved beyond our being able to detect absolute speed as being the violation, and (arbitrarily) extended it to existence of such "special frames"?
That is the same thing. If you can detect absolute speed then the frame where the absolute speed is zero is a special frame.
We cannot detect absolute speed ... that is the point ... please review my reply to Nugatory above!
Please reread Dale's response. If you can define a special frame, then you can define an absolute speed. That is the point.
I think you have this backwards. Two clocks in the train always match. A clock on the train and a clock on the platform only match when the two are at relative rest.
The two clocks on the train are always at relative rest. If they don't match, then, the reason would have to be some absolute sense of motion. The principle of relativity says that this never happens and experiment agrees so far.
I created this thread to *rigorously* examine the claim, such as in Brian Greene's book, that principle of relativity prohibits different clock mechanisms from having different time dilation. I emphasize "rigorously."
In my opinion, rigorous examination must bring in the formal principle of relativity. Principle of Relativity: (1) the laws of physics are the same in all inertial frames; (2) that means there is no preferred frame and no way to detect absolute motion.
If different clock mechanisms had different time dilation then inertial frames where two clocks were manufactured (to be in sync) could be called "special frames" to these clocks; in other inertial frames these clocks could give different amounts of time dilation and fall out of sync. But there would be infinite "special frames" and this infinite family cannot rigorously be called preferred frames in terms of violating the Principle of Relativity. If you insisted on so calling them then (1) the laws of physics would still be the same in all of these; (2) there would be no way to detect absolute motion because whichever frame you chose to manufacture two clocks in sync would be "special frames" and so all frames would be "special frames".
That would lead to paradoxes. Imagine a bomb triggered when those two clocks deviate from each other. Different frames would then disagree on whether the bomb goes off, or not. So this possibility is ruled out implicitly for consistency reasons.
Your assumptions do not lead to your conclusion, it would indeed be possible to detect absolute motion with your clocks working as described if they had different time dilation in different frames. Here's how:
Let's call the clocks A and B. They are made to run synchronous when at rest in some inertial frame. If time dilation was to affect these two clock differently then by taking them to rest in other inertial frames you would first discover anisotropy(*), in some frames A would run faster than B, in others B would run faster than A, and yet in others A and B would run at the same rate. So you will find a unique axis of relative motion along which the difference for the same relative speed is maximum. You then repeat the experiment in frames moving relatively along this particular axis (in both directions) and you will find an inflection point, the rate difference increases up to this point then decreases again. The frame containing this inflection point is the absolute rest frame.
Of course this does not happen in reality because all clocks are affected equally by time dilation.
EDIT: (*) If you don't find anisotropy this means the initial rest frame where you set up the synchronized clocks was already the absolute rest frame.
You have misunderstood one of Greene's points. This point has nothing to do with time dilation: Two clocks aboard the train -- any two clocks -- will stay in sync whether the train is moving or not. If that were not the case then the absolute motion of the train could be detected.
Now, there's another point being made, let's call it the second point, and you seem to be conflating it with the former, which we'll call the first point. Greene's second point is that one of those two clocks aboard the train will not be in sync with a clock on the platform.
He's using the first point to illustrate the first postulate. He's not using the second point to illustrate the first postulate, he's instead using it to illustrate time dilation. You seem to be saying that he's using the first point to illustrate time dilation, but he's not.
Google gives a lot of results when enter: "time dilation" bomb paradox
The train folks have their Rolex and Light Clock, and platform folks have their own Rolex and Light Clock. All clocks on the platform and train were in sync when train was at rest on platform.
Suppose the Rolex and Light clock follow slightly different time dilation formulas. On the moving train Rolex and LightClock would go out of sync.
It would be true that each observer would see other's clocks as ticking at a slower rate than their own clock - whether comparing their Rolex or Light Clock. But it would not be true that to each observer the other's clock is out of sync.
In fact knowing the slightly different time dilation formulas, Formula-Rolex and Formula-LightClock, the platform folks would correctly calculate that the train's clocks would be out of sync. And the train folks would indeed see their clocks out of sync. The train folks, also knowing the different formulas, and calculating using the time on their clocks, would correctly calculate that the platform's clocks would be in sync.
If both the train and the platform had a bomb triggered when their two clocks deviate from each other, then both would agree that the train blows up and not the platform.
It would still be true that each observer would see other's clock as ticking at a slower rate than their own clock - whether comparing their Rolex or Light Clock. There would be slightly different time dilation formulas, Formula-Rolex and Formula-LightClock. It is not haphazard as you suggest.
Please explain in detail how "absolute motion of the train could be detected" if clocks did not stay in sync.
I did not mention any other observes, comparing clocks in relative motion or any time dilation formulas. Please read again and try to follow.
My analysis includes a single observer holding two clocks in his hand, which clocks supposedly would be affected differently by time dilation. This single observer compares the rates of these two clocks which are always mutually at rest, and at rest wrt the observer. He does this in the initial rest frame where the clocks are synchronized because they were created that way. He then changes speed, together with the clocks, in steps and in different directions and compares the rates of the same two clocks side by side (always at rest wrt each other and the observer but in different inertial frames). That's all it takes, no different observers, no comparing of clocks that are moving wrt each other, no time dilation formulas.
The train folks have their Rolex and Light Clock, and platform folks have their own Rolex and Light Clock...
You complicate the issue and confuse yourself. Keep it simple:
Consider just two clocks, Rolex and Light Clock, both at rest on the platform, sitting right next to each other, on the bomb. If they stay in sync in the platform frame, the bomb doesn't go off. Since all frames must agree that the bomb doesn't go off, all frames must agree that they stay in sync. So there is no frame where the clocks have different time dilations.
The point is that if the time dilation was different for the light clock and the rolex, then the principle of relativity would be false. Because a pair of a light clock and a rolex next to each other not moving with respect to each other on the platform would tick at the same rate. Another pair on the train would tick at a different rate. So how do you reconcile that with the relativity principle?
I explained and agree with what you state: "Since all frames must agree that the bomb doesn't go off, all frames must agree that they stay in sync."
"They" refers to the clocks on the platform.
But your conclusion "So there is no frame where the clocks have different time dilations" does not follow. We have different time dilations and yet all agree that the the clocks on the platform stay in sync. I explained that.
...the point being that someone else in motion relative to the clocks must see them as dilated. By different amounts, according to you, @Physics_Teacher.
Unless you are proposing that "the rest frame of the clock" is clock-specific, but that just raises the question of which frame you mean. The frame I used when I synchronised the clocks? The rest frame of the clocks when they were first synchronised? Or when they were last synchronised? What about if I change the function of the clock while it's working (e.g. add weight to the pendulum) - does that reset the frame? How does the clock record which is the correct frame?
Edit: note that you dump the principle of relativity unless you can answer that last question in operational terms: two identical clocks in identical states of motion function differently - why?
Edit 2: Never mind. You lose the principle of relativity whatever you do with this scheme, because you end up with the clocks behaving differently depending on whether I change speed or the clocks do.
Let me rephrase for clarity:
There is no frame where the two clocks on the platform tick at different rates, compared with each other. So they must both obey the same time dilation formula in all frames.
You have two clocks on board the train. When the train is not moving the clocks stay in sync. But when the train is moving the clocks do not stay in sync.
Do you have a reference that supports this claim? I doubt that there exist any "slightly different" time dilation formulas that satisfy the two postulates.
And do you have any references supporting this claim?
When I say: "Suppose the Rolex and Light clock follow slightly different time dilation formulas" I am addressing the argument (such as in Brian Greene book quoted by me) that First Postulate would be inconsistent with this case. I am not saying this IS the case - I am saying "Suppose" it was. I have never suggested that there exist "slightly different" time dilation formulas that satisfy the two postulates.
When I say "If different clock mechanisms had different time dilation..." I am again continuing discussion of whether "IF" this happened that would violate the First Postulate.
I had made it clear that I was not saying the Lorentz transformations have alternatives or suggesting that I have a reference that they do. I was discussing a narrow hypothetical situation based on "IF clocks gave different time dilation." Indeed Greene and others have discussed this, and I am addressing their discussion.
I understand that, but even so your "suppose" needs to be self consistent. I strongly doubt that it is, hence the request for a reference. I think that your argument rests on inconsistent premises. It is common for the professional scientific literature to include suppositions, but they generally justify them carefully.
My reference is the discussion such as in the Greene book, which I quoted from. I think his suppose -- Suppose the Rolex and Light clock follow slightly different time dilation formulas -- is an acceptable suppose. I think this is a "self consistent" suppose. I don't know why you doubt it is. It is his "suppose" and not my original "suppose." I am following his "Suppose" and discussing his reasoning and the conclusion he reaches.
This reference clearly does not support your argument. It also is not a professional scientific reference.
For clarity, I understand that you are supposing that a light clock and a Rolex may have different time dilation formulas and yet satisfy the principle of relativity. That is exactly the opposite of what Greene claims and that is what I am asking you to justify.
Dale said:
This reference clearly does not support your argument. (It also is not a professional scientific reference)
I am trying to critically examine Greene's argument and reasoning that IF different clocks gave different time dilation THEN the First Postulate would be violated. Is it well-settled that it would? If so, I would appreciate a "professional scientific reference". I could ask Greene for a "professional scientific reference" but we know he does not have time to read most of the emails he gets - he said so himself.
