Does this real sequence necessarily converge?
The discussion revolves around the convergence of a real sequence (x_n) defined by the condition |x_n - x_(n+1)| < (1/n) for all natural numbers n. Participants are exploring whether this condition guarantees convergence, referencing the Cauchy Criterion for sequences.
  • Participants are considering the implications of the sequence being Cauchy and questioning whether the decreasing differences between terms imply convergence. Some are exploring counterexamples, particularly through the lens of sequences of partial sums.
The discussion is active, with participants raising various approaches and counterexamples. There is a focus on the sequence of partial sums of the harmonic series and its divergence, alongside attempts to clarify the relevance of specific properties of sequences. No consensus has been reached yet.
Participants are navigating the complexities of convergence criteria and the implications of the given condition on the sequence. There is mention of the Cauchy Criterion and the behavior of the harmonic series, which may influence their reasoning.
zebraman
Let (x_n) be a real sequence which satisfies |x_n - x_(n+1)| < (1/n) for all natural numbers n.
Does (x_n) necessarily converge? Prove or provide counterexample.
I figured at first that this would be easily solved by determining if this sequence was a Cauchy sequence since the difference between the terms decreases with each successive term, but you don't know that you can always find a point after which the terms x_n, x_m have a difference of less than an epsilon. Any suggestions?
Can you think of a series whose partials sums diverge while satisfying the requirement:
|s_n - s_(n+1)| < (1/n)?
Well I was thinking the sequence of partial sums of the sequence x_n = 1/n diverges (Harmonic Series). But I guess since |x_n + x_(n+1)|<(1/n) that won't work.
In the sequence
[tex]s_n = \sum_{i=1}^n \frac{1}{i}[/tex]
what is the value of |[tex]s_n - s_{n+1}[/tex]|?
|s_n - s_(n+1)| = 1/(n+1), so are you saying that will serve as a counter argument? Because doesn't the sequence x_n = 1/n converge?
1/n converges. But sethric is suggesting using the sequence s_n, not 1/n. If you know the series 1/n diverges then you know the sequence of partial sums diverges. If you want a more easily expressed answer you might want to think about using an approximation to s_n. What is it?
Sorry, I don't understand what you're asking.
I'm asking if you know that s_n is approximately equal to log(n) by an integral test.
No, but is that important?
Dick is correct, I was suggesting to use the sequence s_n. You have already shown:
|s_n - s_(n+1)| = 1/(n+1) < 1/n
You have also already said s_n diverges.
No, it's not important if you use sethric's suggestion. It's another series that has similar properties to the s_n.
