Is Drying Air Before a Compressor the Best Way to Limit Water Vapor?
  • Thread starter Thread starter LotteVV
    Compressor
Drying air before a compressor is an effective method to limit water vapor and prevent bacteria from reaching the oil filter located after the compressor. Utilizing a high-quality desiccant air dryer is essential to achieve the desired pressure dew point. Although this approach may incur higher costs compared to drying air post-compression, it can be beneficial in specific applications where moisture control is critical.
  • Understanding of desiccant air dryers
  • Knowledge of pressure dew point concepts
  • Familiarity with compressed air systems
  • Awareness of bacteria growth in oil filters
  • Research the specifications and performance of desiccant air dryers
  • Learn about pressure dew point measurement techniques
  • Explore methods for moisture control in compressed air systems
  • Investigate the impact of moisture on oil filter performance
Engineers, technicians, and maintenance personnel involved in compressed air systems, particularly those focused on moisture control and system reliability.
LotteVV
Hi,
I was wondering if a dryer is ever placed before the compressor? For limiting the presence of water vapor before the compressor inlet, I was thinking of drying the air before the compressor (it's a closed system btw). Is this the right technique? Or you this be done otherwise?
Limiting the water vapor is so make sure no bacteria can reach the oil filter that is located right after the compressor.
Kind regards
Lotte
It can be done, but you would need a good desiccant air dryer because you are up against pressure dew point (search those terms). Here is one good hit: https://www.vaisala.com/sites/default/files/documents/Dew-point-compressed-air-Application-note-B210991EN-B-LOW-v1.pdf
It would be more expensive than drying the air after compression, but it just might be worthwhile in your case.
14K
  • · Replies 39 ·
15K
  • · Replies 19 ·
