Eight month numbers adding to 49 over 10 years
17 replies · 3K views · last reply
BBBOB
Misplaced Homework Thread -- Moved to the Schoolwork forums
TL;DR Summary: Eight Exact To Get 49
Please advise if I am wording this problem correctly and what are the solution (is there some equation for combinations )/ Answers:SET of numbers 1,2,3,4,5,6,7,8,9,10,11,12 months of the year.
Within the exact time frame of 10 years I MUST choose a number of the month each year that when combined with other months (their number placement in the calendar) over those ten years in total add up to 49.
Constraints:
I must to use exactly eight of the above numbers when added together produce the number 49 over those ten years
Numbers can be used over (repeated) but MUST be eight in total over those ten years.
Questions:
1) How many combinations are there that will equal 49
2) What are those number combinations of eight numbers when added together that equal 49? over those ten years.
---------------------------I'm looking for how many combinations there are
Example:
10,7,5,7,7,4,1,8 ----- these eight when added get 49
10,9,8,7,6,5,3,1 also adds up to 49
No you are not: the constraint "Within the exact time frame of 10 years" is not explained.
PeroK said:
You could write a computer programme to calculate this?
In British English a "computer programme" would be something you watch on television about computers, in the same way as The Sky at Night is an "astronomy programme". When you programme a computer, you write a computer program.
What does this mean?
BBBOB said:
Example:
What do these examples have to do with "the exact time frame of 10 years"?
I agree. As stated, the problem doesn't make sense.
Yes, this is very confusing. How is month 8 of one year different from month 8 of another year? What does the year have to do with anything in the problem?
Respectfully disagree with Mark44 and pbuk. The term "combinations" suggests that e.g. 1, 3, 5, 6, 7, 8, 9, 10 will suffice for one partition of 49. The term "10 years" suggests that these numbers, in that order, must be entered in 10 slots or less. That says the finite sequence mentioned can be entered in any of 10C2 = 45 ways. You guys are far above me mathematically; but I'm on another board, where ill-posed problems are par for the course. Thanks for the chance to comment!
The 8 in total over 10 years makes no sense though. Why not just 8 years?
Sorry for the confusion and its mu wording but i was able to use a SUM calculator to get all the combinations that I needed. So this was solved! Thank You Bob
What exactly was the problem you were trying to solve?
Trying to see what combinations in only eight digit places add up to 49. Project Im working on. but I have another question which I will post related to such. Thanks! Bob
It would have been helpful and less confusing if you had included this in your original post. The business about "Within the exact time frame of 10 years" was a red herring that confused most of the people replying.
A clearer problem description might be something like this:
Using the numbers 1, 2, 3, ..., 12, how many combinations of exactly eight of these numbers add up to 49? A combination can include repeats of these numbers.​
If you want to get good answers, it helps to ask a good questions.
Point taken, you are so right. In math how you word it is crucial! Thank you again!
This seems like your standard "Stars and Bars " problem,
https://en.wikipedia.org/wiki/Stars_and_bars_(combinatorics)
if I understood it correctly.
##x_1 +x_2 +....+x_k= n; x_i \geq 0 ##* The answer, with ## x_i >0 ## for the count (**)
is ## C_{n-1,k-1} ## ("## n-1 ##choose ##k-1##"), though it won't exclude ##x_i >12##
Here, ##C_{49-1, 4-1}=C_{48,3}=17,296 ##
* There's a version that requires ## x_i >0 ##t
** Or the countess, to be inclusive ;)
