Element in a ring mapping one prime to the next
tomelwood
Let {p_n}n>0 be the ordered sequence of primes. Show that there exists a unique element f in the ring R such that f(p_n) = p_n+1 for every n>0 and determine the family I_f of left inverses of f.
The ring R is defined to be: The ring of all maps f:Q+-->Q+ such that f(rs)=f(r)f(s) for every r,s in Q+. Define the operations + and x in such a way that (f+g)(r) = f(r)g(r) and (f x g)(r) = f(g(r)) for every r in Q+. This is a non commutative unitary ring with zero divisors.
Any pointers would be appreciated, as I cannot see how it is possible to map one prime to the next, given any prime, let alone find the unique f in the ring R that will do it.
Sorry that I haven't provided more, but I have literally been banging my head against a wall for ages on this question, without the faintest idea of where to start!
First we define this map on the primes. So we define f(p_n)=p_{n+1}.
We wish to extend this map to the entire of Q. Take q in Q. Then the prime factorization yields that we can write q as
q=\prod_{I\subseteq \mathbb{N}}{p_i^{n_i}}
For a certain finite set I and n_i\in \mathbb{Z}
The only possibility to define f(q) is as
f(q)=\prod_{I\subseteq \mathbb{N}}{f(p_i)^{n_i}}=\prod_{I\subseteq \mathbb{N}}{p_{i+1}^{n_i}}
Try to show for yourself that f, with this definition, satisfies f(ab)=f(a)f(b).
Thanks so much, this has been most helpful!
So I got f(qr) = ...= PROD (p_i+1)^ni PROD (s_i+`)^ni = f(q)f(r) which is all I need to prove, right?
So now I need to determine the family of left inverses, which I believe is defined to be I_f = {g in R : gf = 1_r}
So the elements in R are these functions f,g etc. So I need to find the set of these g's which 'cancel out' the f's.
So if I do g(q)f(q) = PROD (g(p_i)^ni) PROD (p_i+1^ni) = 1_R
So I need to find this g. How do I do that.
I was tempted to say whilst writing this that g(q)f(q) = by definition of addition in this R = (g+f)(q) but I don't know if that would have helped at all? Thanks.
Yes, you've proven correctly that such an f exist. But you still need to determine for f what f(0) and f(1) is. I forgot to mention it.
For the other question, let g be a left inverse of f. g is uniquely determined by how it acts on the primes. So we simply need to know what g(p_i) is.
Since g is a left inverse, we must have that g(p_{i+1})=p_i. This defines g on every prime number except 2. For 2, we may choose what g(2) is.
OK. Well surely f(0) is 0 as 0=PROD 0 so f(0) = PROD 0 = 0
and 1 = PROD 1 so f(1) = PROD 1 = 1 ? That seems a little too simple to be true though.
So the set of all these g's is I_f = {g in R : g(p_i+1) = p_i, g(2) = 1} ?
No, you don't need to map 2 to 1. g(2) can be anything. We can only say that I_f = {g in R : g(p_i+1) = p_i}
For every q\in \mathbb{Q}^+, we can find a g in I_f: the g that maps 2 to q.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
