Energy conservation (2 carts and a spring)
The discussion revolves around a physics problem involving energy conservation and momentum for two carts connected by a spring. The original poster describes the setup, including the spring constant, masses of the carts, and the compression distance of the spring. The goal is to determine the speeds of the carts after they are released.
  • Mixed
  • Participants explore the application of conservation of energy and momentum, questioning the initial conditions and the implications of momentum conservation when the carts are initially at rest.
Some participants have offered guidance on using conservation of momentum to create a second equation to solve for the unknown speeds. There is an ongoing exploration of the relationships between kinetic energy and momentum, with participants attempting to manipulate the equations to find a solution.
Participants note the initial momentum is zero due to the carts being at rest, which raises questions about how momentum conservation applies in this scenario. There is also mention of potential algebraic difficulties in solving the resulting equations.
mujadeo
A massless spring of spring constant 20 N/m is placed between two carts. Cart 1 has a mass M1 = 5 kg and Cart 2 has a mass M2 = 2 kg. The carts are pushed toward one another until the spring is compressed a distance 1.5 m. The carts are then released and the spring pushes them apart. After the carts are free of the spring, what are their speeds?
I am using K_f + U_f = K-i + U_i
Why doesn't it work?
OK here's what I know
U_i = 1/2k delta s^2
= 22.5J
K_i = 0 (because object initially not moving)
U_f = 0 (because carts now moving)
K_f = 1/2 mv^2
Energy is conserved, so 1/2mv^2 must = 22.5J.
Also, 22.5J is the kinetic energy of BOTH carts
So 22.5J = K (of cart 1) + K (of cart 2)
so that leaves me with 2 unknowns in each equation for each cart?
1/2mv^2 (cart 1) = (some amount of 22.5J)
1/2mv^2 (cart 2) = (some amount of 22.5J)
Please Help,
(Thanks)
(ALSO, I do understand that potential E is converting to kinetic E and the amount is conseved
and also that momentum is conserved)
Conservaiton of energy always works... so does Conservation of momentum...
Since you already have one equation with two unknown, i.e.
[tex]22.5 = 1/2m_1v_1^2 + 1/2m_2v_2^2[/tex]
why don't you apply the conservation of momentum to add one more equation to the problem and make it become 2eqn 2 unkn...
OK but how could it have initial momentum if its not moving initially ?/
p=mv (v=0)
cause that would mean momentum not conserved right?
Okay... that's mean the initial momentum p = 0...
And the final momentum depends on two object moving toward opposite direction, that's mean
[tex]m_1v_1 = m_2v_2[/tex]
understand?>
OH, so in opposite directions so they must add to zero?
They are in opposite direction, so one must be positive while the other one must be negative, let's say v1 is moving to the positive direction, that's mean v2 must be negative... i.e.
[tex]m_1v_1 + m_2(-v_2) = 0[/tex]
SO if I have
22.5 = 1/2m1v1^2 + 1/2m2v2^2
and
m1v1 = m2v2
and set them equal to each other:
m1v1^2 + m2v2^2 - 45 = m1v1 - m2v2
I am still left with v1 + v2 = (some number) after all the algebra (unless my algebras bad)
Bad algebra indeed.
You have two equations and two unknowns, this can be solved.
You can easily use the second equation (momentum) to eliminate one of the variables in the first equation (energy) and to solve this equation then.
It is a common problem in physics: you have the total energy in a frame of reference where the total momentum is zero.
Another example of this problem is the recoil of a gun. If you think of it, you see it is the same problem.
In particle physics, when a particle (U238 e.g.) decays in two fragments, the total energy of the reaction (spontaneous fission) is split in the fragments, but the total momentum is not changed (zero if in the proper frame).
Write down the general solution to this problem (not only your specific numbers) and analyse it, it is interresting.
  • · Replies 32 ·
  • · Replies 40 ·
  • · Replies 17 ·
  • · Replies 16 ·
