Eqn for SHM, sin function, so why cos?
3 replies · 3K views
ZedCar
I had thought the eqn of simple harmonic motion is a sinusoidal function of time, with the eqn being:
x(t) = A sin(wt + ∅0)
Halfway down this page:
http://electron9.phys.utk.edu/phys135d/modules/m9/oscillations.htm
in Problems:
in solution (a) it gives;
The displacement as a function of time is x(t) = Acos(ωt + φ).
Why are they using a cos and not a sin function?
Which one you use is arbitrary. Realize that the only difference between the two is a phase factor. (Shift a sine function by 90° and it becomes a cosine function.)
Using x = Acosωt just implies that you are starting the clock when the object is at its maximum displacement. Using x = Asinωt implies that you are starting the clock when the object passes the equilibrium point.
Just two completely equivalent ways of describing the same thing.
Doc Al has said it... you will not hear a more straightforward explanation
