I Faster Than Light Travel: Wormhole Questions
  • I
  • Thread starter Thread starter Bob Porter
    Wormhole
Bob Porter
When a wormhole opens, if each side of space is equally stretched to meet each other. Then wouldn't it be possible to only go halfway through the wormhole, close it and allow the opposite side of space you're trying to reach, "normalize" and wouldn't the space on the side you've traveled to that "normalized" return to itself faster than the speed of light allowing for faster than light speed travelling?
That is not a good description.
If wormholes are possible, they allow you to reach some destination faster than light would need for the regular trip (without wormhole). There is no need to close a wormhole or whatever. The wormhole itself provides a shorter connection. You never travel faster than light - you just take a shorter connection. Light going through the wormhole as well would still be faster than you.
Also, if wormholes are possible, it is nearly impossible to avoid time travel paradoxes.
What I was trying to say was, If I used my incredible technology to open a wormhole to travel to you, in which you are several thousand light years away. At the same time, you opened a worm hole allowing the worm hole to be opened faster. Then once I travel technically to you, the space you were controlling, turn my technology off, then turn off your tech. Your side of space would return to normal in half the time since your technology only had to establish the connection half way.
That doesn't make sense.
Also, while we do not have wormhole generators for a reliable time estimate, the typical timescale for the process would be the size divided by the speed of light - less than a microsecond for all practical purposes. There is no need to speed up a process that takes a microsecond.
Likes Fervent Freyja
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
