What Do ##\phi## and ##\psi## Represent in Quantum Field Theory?
  • Context: Undergrad
  • Thread starter Thread starter Silviu
    Qft
In Quantum Field Theory (QFT), the hermitian operator ##\hat{\phi}(x)## represents a quantized scalar field, while ##\phi(x)## denotes the classical field, which is a function of spacetime coordinates. The configuration space wavefunction ##\psi(x_1, ..., x_n, t)## corresponds to the n-particle Fock state, derived from the expectation value of the field operators. The Hamiltonian in QFT, denoted as ##\hat{H}(\hat{\phi}, \hat{\pi})##, is always hermitian, contrasting with the non-hermitian nature of some field operators. The transition from first quantization to second quantization reflects a shift from treating fields as wavefunctions to operators that govern particle interactions.
  • Understanding of Quantum Field Theory (QFT)
  • Familiarity with the Klein-Gordon equation
  • Knowledge of quantum states and Fock space
  • Basic concepts of classical and quantum Hamiltonians
  • Study the derivation of the Klein-Gordon equation and its solutions
  • Learn about the role of creation and annihilation operators in QFT
  • Explore the mathematical formulation of Hamiltonians in quantum mechanics
  • Investigate the implications of second quantization in particle physics
Physicists, quantum field theorists, and students of theoretical physics seeking to deepen their understanding of field operators and their role in particle interactions within QFT.
Silviu
Hello! So I understand that in QFT and based on the second quantization, one introduce the hermitian operator ##\hat{\phi}(x)##. So, if we have a state with n particles ##|n>## we can get the configuration space representation as: ##\psi(x_1,..,x_n,t)=<0|\hat{\phi}(x_1)...\hat{\phi}(x_n)|n>## (please let me know if anything I said is wrong). Then I read that writing the action for a field, in the end we can derive ##H[\pi,\phi]##, with ##\pi## the conjugate momentum of ##\psi## and here is where I get confused. What is the meaning of ##\phi## without a hat? It means it is just a scalar field, not a field operator? So it is just as ##\phi## was previously, in the first quantization QM? And if in the end we go back to a scalar field and not an operator, what is the point of the second quantization? I.e., if we solve the Klein-Gordon equation for ##\phi(x)## we still get a plane wave, so where is the operator-like behavior of ##\phi##? And I see that both ##\phi## and ##\psi## appear in this formalism, so they can't represent both the same thing. Thank you!
Firstly, a field operator \hat{\phi}(x) is not necessarily hermitian. For example, a complex scalar field is not hermitian but the Hamiltonian is always. A more clearer statement would be \langle 0|\hat{\phi}(x_1)\hat{\phi}(x_2)...\hat{\phi}(x_n)|n\rangle is the configuration space wavefunction \psi(x_1,x_2,...x_n), corresponding to the n-particle Fock state.
You're mixing up quantum states with fields. For a classical field \phi(x), it has a classical Hamiltonian (density) which is a function of the field \phi(x), and the corresponding conjugate momentum \pi(x) i.e., H=H(\phi,\pi). There is nothing called conjugate momentum of \psi. I think, it's a typo in your question.
\phi(x) is the classical field, a function of spacetime coordinates x. In the quantized version, the scalar field \hat{\phi}(x) is a promoted to the status of an operator (not necessarily hermitian). The quantized field Hamiltonian is however a hermitian operator and is given by \hat{H}=\hat{H}(\hat{\phi},\hat{\pi}).
Second quantization is a bad name. Historically, the field \phi(x) used to be regarded as the wavefunction and Klein-Gordon equation as a relativistic generalization of Schrödinger equation. This used to be called first quantization. However, relativistic quantum mechanics has severe pathologies and therefore was later superseded by quantum field theory (QFT). In QFT, \phi(x) is no longer the wavefunction of a relativistic particle. The wavefunctions are what you mentioned i.e., \psi.
Yes. The solution of Klein-Gordon equation can be decomposed in terms of plane-waves with amplitudes. Those amplitudes are numbers in classical field theory and promoted to creation and annihilation operators in QFT.
  • · Replies 30 ·
  • · Replies 17 ·
