Find angle ABC in rhombus ABDF with equilateral triangle ACE
  • Thread starter Thread starter Natasha1
    Geometric
24 replies · 3K views · last reply
Natasha1
As shown in the diagram (attached), ABDF is a rhombus, ACE is an equilateral triangle, and AB  AC . Find ABC through geometric reasoning (a scale diagram will gain no credit).
2. See drawing (picture attached)
If I make angle ABC = x then BCA is also = x (as triangle ABC is isosceles) so I got x + x + 180 - 2x = 180
angles ACE = CEA = EAC = 60 degrees (Equilateral triangle)
Must I use alternate angles to help me solve this problem...
if BCA = x then CAF = x (alternate angles)
CAE = 60 but what is EAF = ?
What has that to do with my hint? What is the difference between a rhombus and a general parallelogram?
Natasha1 said:
So we have ABC = BDF = DFA = x
No, BDF is not equal to the other two.
You need to use that it is a rhombus, not just a parallelogram. Find two sides that are equal in the rhombus but might not be in a parallelogram.
So ABC = DFA = x
in each triangle we get x + x + 180 - 2x = 180 (but then this is obvious)
Natasha1 said:
So ABC = DFA = x
I repeat:
In quadrilateral CEFA we have 60+x+x+180-2x+60+60=360 but then 360 = 360 leads nowhere
Natasha1 said:
all 4 sides are equal in a rhombus
Yes, but some are also equal in a parallelogram. I repeat
Natasha1 said:
i give up
As you said, all four sides are equal in a rhombus. That is not true of a parallelogram. In a parallelogram, which sides must be equal? Which sides need not be equal? Answer in terms of 'adjacent' and 'opposite'.
Natasha1 said:
Opposite
Which question is that the answer to? I asked which must be equal and which need not be equal. The answers are different, obviously.
In the rhombus ABDF, AB = BD = DF = FA
In a parallelogram opposite = equal, adjacent = not equal
How can knowing that triangles ABC and AFE are isosceles and similar help me in finding angle ABC?
Right, so pick some pair of adjacent sides.. AB and BD say. You know these are equal. What isosceles triangle does that give you?
Natasha1 said:
similar isosceles triangles
I mean with reference to the points in the diagram. Choose two adjacent sides of the rhombus and say which you have chosen. You know they are equal length, so they form two sides of an isosceles triangle. Which triangle? What angles are therefore equal?
