Find Projectile Flight Time Given Only Maximum Height
4 replies · 3K views
trryan5
A projectile reaches a maximum height of 14.5 meters and travels a horizontal distance of 52.6 meters. How long was it in the air?
Vfy = V0y - 9.8t
I've been trying some online projectile problems. Specifically, I was using this one on master difficulty, looking at row e. It uses a random number generator; I shared the data I received in the Homework Statement above.
According to the help section, you can solve this with the formula given, but I don't see how. In fact, they seem to suggest that you don't even need the horizontal displacement, and can figure out the flight time of a projectile with just its maximum height, but there are lots of combinations of angles and velocity that will produce the same maximum height with different flight times.
I sort of cheated my way into a solution using this calculator. Note the calculator can't solve for time with just the two pieces of data given. What I did was put in horizontal distance (and initial height of 0) and start guessing at times until I found that 3.44 seconds produces a height of 14.5 meters.
Can anyone explain to me the correct approach to solving this problem?
That is correct.
Why do you think this?
Hint: Analyze just the vertical component of the motion. You can play with the kinematic formulas until you can solve it.
Hint2: For an object dropped from that height, how long would it take to fall?
trryan5 said:
... figure out the flight time of a projectile with just its maximum height, but there are lots of combinations of angles and velocity that will produce the same maximum height with different flight times.
Consider these three baseball throws:
Knowing nothing else, at a guess, do you expect the three of them to have different flight times?
What if I told you they were not three baseball throws, but only one, just viewed from different locations on the field? What would you say about flight time now?
Doc Al said:
That is correct.
Ah, now I feel foolish. I was so focused on not knowing the initial upward velocity that I didn't think about analyzing it as an object in free fall.
You could also consider two frames of reference. One at rest relative to the ground. And the other moving with the horizontal velocity of the projectile. The time of flight is the same in both (as it must be), yet the horizontal velocity and displacemet are different in each.
