Find the Missing Angle in Triangle ABC: Use Arithmetic Sequence and Sine Rule
  • Thread starter Thread starter Physiona
    Angles Arithmetic
12 replies · 3K views
Physiona
QUESTION:
The angles in triangle ABC form an increasing arithmetic sequence.
The ratio of angles A:B:C can be written in the form 185:370:555 respectively.
You are told that the total area of the triangle is 9
Length BC is
Given the area of triangle ABC, work out the value of
Give your answer in the form
where
and
are integers.
ATTEMPT:
I have decided to figure out a multiplier for all the angles provided, and labelled it as y
y(185+370+555)= 180
1110y = 180
y= 6/37
I am then planning on using the sine rule however, I don't have set values to use only angles. I'm not sure on whether or not my attempt is correct. Any guidance to helping? Thank you!
  • chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=units%7B%5C+%7D%5E%7B2%7D.png
  • chart?cht=tx&chf=bg,s,FFFFFF00&chco=000000&chl=x%3D%5Csqrt%7Ba%5Csqrt%7Bb%7D%7D.png
Physiona said:
QUESTION:
View attachment 222907View attachment 222908
You are told that the total area of the triangle is 9View attachment 222909
Length BC is View attachment 222910
Given the area of triangle ABC, work out the value of View attachment 222911
Give your answer in the form View attachment 222912 where View attachment 222913 and View attachment 222914 are integers.
ATTEMPT:
y(185+370+555)= 180
1110y = 180
y= 6/37
The angles form an increasing arithmetic sequence. How have you used that information?
Erm, I think I've used it in this way.
After I have found out the multiplier of 6/37, I multiplied each part of the ratio by it.
185*6/37= 30
370*6/37= 60
555*6/37= 90
This eventually forms an arithmetic sequence right? 30, 60, 90. (Increasing by 30 each time)
I have used to sine rule to then find the length of AC.
a/sin a = b/sin b
x/sin(30) = AC/sin(60)
Rearranging for AC = is root3/4 x = AC
I've then used the area of a triangle to figure out x
A = 1/2ab*SinC
9= 1/2*1/2*root3/4x*x*sin(30)
18= 1/2*root3/4x2
36=root3/4x2
Rearranging it for x= root 48 over root 3.
185*6/37= 30
370*6/37= 60
555*6/37= 90
I got the same numbers, but in a more straightforward way, I think.
Let a = the smallest angle. The the three angles are a, a + h, a + 2h. Since (a + h)/a = 370/185, then 185(a + h) = 370a, or simplified, a + h = 2a, from which we get h = a. This means that the angles are a, 2a, and 3a, from which we get a = 30° and the other two angles are 60° and 90°.
Your drawing is not very helpful. Is A the angle at the left and C the angle on the right? And in your work below, which side is x?
Since you have a 30-60-90 right triangle, it's much simpler to note that if x is the length of the short leg, then 2x is the length of the hypotenuse, and the other leg is ##\sqrt 3 x##.
Physiona said:
a/sin a = b/sin b
A = 1/2ab*SinC
18= 1/2*root3/4x2
36=root3/4x2
You have ##\frac{\sqrt{48}}{\sqrt{3}} = \sqrt{16} = 4##. I get a different result, which is in the form of ##\sqrt{a \sqrt b}##, which produces the right area and works in the Pythagorean Law.
You have ##\frac{\sqrt{48}}{\sqrt{3}} = \sqrt{16} = 4##. I get a different result, which is in the form of ##\sqrt{a + \sqrt b}##, which produces the right area and works in the Pythagorean Law.
Basically the diagram didn't upload right, so it was difficult to adjust it on here. The angle on the bottom left is A, on the top right is B, and on the bottom right is C (which is a right angle). I'm not sure how you have got ##\sqrt 3 x##.
Can you please explain the method fully with what you have as answer? This is the method my teacher assumed I should follow.
What does the ##h## represent in the equation used? Is it some constant?
If x is the length of the leg opposite the 30° angle, then the hypotenuse length is 2x, and the other leg length is ##\sqrt 3 x##. From the Law of Pythagoras, we have ##x^2 + (\sqrt 3 x)^2 = (2x)^2##.
Physiona said:
What does the h represent in the equation used? Is it some constant?
Yes, it's the constant in the arithmetic sequence. If the sequence starts with a, the next term will be a + h, and the next a + 2h, and so on.
Knowing that the two legs of the triangle are ##x## and ##\sqrt 3 x##, substitute them into your formula for the given area to find x, which is not equal to 4, as you had in your earlier post.
Right okay, I'll have an attempt.
I'm attempting to use the formula of ##1/2abSinC##.
I've got all the lengths of the triangle as ##\sqrt 3 x## and ##x## and ##2x##. The using of the area of a triangle, will that lead me to finding a solution for x? I did it, but I didn't manage to get a correct solution in the form of ##\sqrt{a + \sqrt b}##
I'm still struggling! I come to a final conclusion in finding ##x##, but my calculation is misinterpreted somehow.
I get ##\sqrt 3x##*##x##\2 ##= 9##
I used the area of a triangle, ##b*h/2##.
Now solve for x. You will need to do some algebraic manipulation to get it into the form ##x = \sqrt{a \sqrt b}##.
@Mark44 We were unaware of the duplication, but the OP was able to work to the answer on the other thread, so this one could be closed as well.
The other thread, which was started after this one, was closed because it was a duplicate of this thread, not because the OP had found a solution.
