Finding Bearings: Solve Triangle ABD Problem
  • Thread starter Thread starter jaxta
5 replies · 2K views · last reply
jaxta
Hey,
I am studying for a test and i am having trouble with this problem. I have attached a photo of the worked solution. For the first part of the triangle (ABD) I understand everything except how they got the bearing AD. How do you find this bearing from the angle BAD.
  • Printed worked solution titled TRIANGLE Solutions, showing a triangle with vertices A, B and C, a point D on BC, angles 37°25', 87°29', lengths 644 and 668, and the step-by-step solution for triangle ABD.
You know the angle ABD, and angle BAD has just been calculated. Angle ADC follows from these by a bit of basic geometry.
Thanks for your help, but I'm still wondering how to find the bearing AD which is (208°00'20"). I found the angle for BDA (120°31'21") do i need to do something with that to find bearing AD, I am still confused.
Right, so angle ADC is 180 minus that. You now have the bearing of DC and the angle ADC, so it's easy to deduce bearing DA. Just add/subtract 180 for AD.
I looked over it again and that didn't really work out. So angle ADC is 180 minus 120°31'21" . This equals 59°28'39" you said this would equal the bearing DC, however the bearing DC is already given in the question which is 87°29'. I don't know what i did wrong.
I did not say that. I listed what you would know after you had worked out the angle ADC: the angle ADC and the bearing of DC. From those you can compute the bearing of DA.
