Finding CDF of a Continuous R.V.
11 replies · 8K views · last reply
gajohnson
Let
f(x) = (1 + cx)/2 for x between -1 and 1 and f(x)=0 otherwise, where c is between -1 and 1. Show that f is a density and find the corresponding cdf. Find the quartiles and the median of the distribution in terms c.
NA
I simply showed that this was a density by integrating f(x) from -1 to 1 and showing that this is 1.
For the second part of the problem, I found the CDF to be F(x) = 1/2(x+(cx^2)/2) for -1≤x≤1.
Clearly, F(x) = 0 for -1<x. However, is F(x) = 1 for x>1?
In addition, I am having trouble properly interpreting the directions for finding the quartiles and median. Should my answer be a function of c? If so, how do I go about getting there? Thank you!
gajohnson said:
Let
NA
Your CDF is wrong. For ##x<-1, F(x) = \int_{-\infty}^x 0\, dx = 0##. For ##x## bewteen -1 and 1, you should be calculating$$
F(x) = \int_{-\infty}^x f(x)\, dx =\int_{-\infty}^{-1} 0\, dx +
\int_{-1}^x \frac {1+cx} 2\, dx$$Now do you see what to do for ##x>1##?
\int_{-1}^x \frac 1 2 (x + \frac{cx^2}{2})\, dx$$Now do you see what to do for ##x>1##?
Thanks for your response! Why would I be taking the integral of 1/2(x+(cx^2)/2) to find the CDF, and not the integral of (1+cx)/2, which is my density function?
You shouldn't, of course. My eyes fell on the wrong function while typing. I will correct it.
Got it. Thanks!
Do you have any suggestions on the quartiles and medians?
Despite that observation, your cdf is still wrong.
[tex]F(x) = \frac{1}{2} \int_{-1}^x 1 \, dt + \frac{1}{2} \int_{-1}^x c t \, dt, \:<br /> -1 \leq x \leq 1.[/tex] This will = 0 at x = -1 and = 1 at x = 1, no matter what is the value of c.
To get a 100p percentile, solve the quadratic equation F(x) = p.
I am not entirely sure where my CDF is wrong or what you mean about c.
Currently my CDF is as follows:
P(X≤x) = 1/2(x+(cx^2)/2) if -1≤x≤1
0 if x < -1
1 if x > 1
1/2(x+(cx^2)/2) was found by taking exactly the integral that you described.
Do you mean instead that it should be:
P(X≤x) = 1/2(x+(cx^2)/2) if -1<x<1
0 if x ≤ -1
1 if x ≥ 1
Thank you!
0 if x < -1
1 if x > 1
0 if x ≤ -1
1 if x ≥ 1
Thank you!
Do either of the above formulas give ##\lim_{x \downarrow -1} P(X \leq x) = 0## and ##\lim_{x \uparrow 1} P(X \leq x) = 1?## Since X is continuous, these must happen.
gajohnson: don't confuse integral and antiderivate. For instance, try to compute the value of your CDF
[itex]F\left ( x \right ) = \frac{1}{2}\left ( x + \frac{cx^2}{2} \right )[/itex]
for [itex]x=-1[/itex]. Is it what you expected?
The parameter [itex]c[/itex] will govern "how fast" your CDF climbs. Here is a graph of it between [itex]-1[/itex] and [itex]1[/itex], for various values of [itex]c[/itex].
  • Line plot titled "Plot of CDF for (1+c.x)/2" showing seven curves for c = -1, -.5, -.25, 0, .25, .5, 1 over x from -1 to 1, with y from 0 to 1, all passing through (-1, 0) and (1, 1).
Ahhhh, yes. Not sure what I was thinking there.
So, I ought to get F(x) = (x+1)/2 + c/4(x^2 -1) for -1≤x≤1
=1 for x>1
=0 for x<-1
I believe I see what you were getting it (should not have taken so long). How does that look?
jfgobin said:
Looks better to me :-)
Great, thanks for the help, everyone!
