Finding constant c so that E(c*θ-hat) = θ using order statistics
4 replies · 3K views
Artusartos
Suppose [itex]X_1, ... , X_n[/itex] are iid with pdf [itex]f(x,\theta)=2x/(\theta^2)[/itex], [itex]0<x\leq\theta[/itex], zero elsewhere. Note this is a nonregular case. Find:
a)The mle [itex]\hat{\theta}[/itex] for [itex]\theta[/itex].
b)The constant c so that [itex]E(c\hat{\theta})=\theta[/itex].
c) The mle for the median of the distribution.
a) I got [itex]\hat{\theta} = max\{X_1, ... ,X_2\}=Y_n[/itex]
b) I was stuck here...
I need to find the pdf for [itex]Y_n[/itex] using the order statistics formula, right?
So this is what I got...[itex]f_n(y_n)=\frac{n!}{(n-1)!(n-n)!}[F(y_n)]^{n-1}[1-F(y_n)]^{n-n}f(y_n)[/itex]
= [itex]n(F(y_n))^{n-1}f(y_n)= n(\frac{-2x}{\theta})^{n-1}(\frac{2x}{\theta^2})[/itex]
= [itex]n(\frac{-2x}{\theta})^{n}(\frac{\theta}{-2x})(\frac{2x}{\theta^2})[/itex]
= [itex]n(\frac{-1}{\theta})(\frac{-2x}{\theta})^n[/itex]
So now I want to find the expected value, but I'm not sure what the boundaries need to be for the integral...so can anybody help me?
Thanks in advance
Thanks in advance
The formula for ##f_n(y)## must not have x in it! Do you mean
[tex]f_n(y) = n \left( \frac{-1}{\theta} \right) \left(\frac{-2x}{\theta}\right)^n?[/tex]
I hope not, because for even n this whole expression is < 0, so you have a negative probability density.
Why not just use [tex]P\{ \max(X_1,X_2, \ldots, X_n) \leq y \} = P\{ X_1 \leq y, X_2 \leq y, \ldots, X_n \leq y \}\\<br /> = F_X(y)^n[/tex] for iid ##X_i##?
Thank you. So...
[itex]F_X(y)=\frac{y^2}{\theta^2}[/itex], right? So...
[itex]P\{ \max(X_1,X_2, \ldots, X_n) \leq y \} = P\{ X_1 \leq y, X_2 \leq y, \ldots, X_n \leq y \} = P(X_1 \leq y)P(X_2 \leq y)...P(X_n \leq y) = (\frac{y^2}{\theta^2})^n[/itex], right?
But I'm still a bit confused about the boundaries for the intergral for the expected value...
Artusartos said:
Thank you. So...
Of course you need ##0 \leq y \leq \theta## in the above. For ##y > \theta## we have ##F_Y(y) = 1##.
Thanks a lot. When I use the technique that you suggested, I get...
When I use the order statistics (I did it again, because the one I did before was wrong), I get...
= [itex]n(F(y_n))^{n-1}f(y_n)= n(\frac{{y_n}^2}{\theta^2})^n(\frac{\theta^2}{y_n})(\frac{2y_n}{\theta^2}) =(\frac{2n}{y_n})(\frac{{y_n}^2}{\theta^2})^n[/itex]
This question is also solved in this link (question 2):
http://www.math.harvard.edu/~phorn/362/362assn6-solns.pdf
All three of these answers are different. I keep repeating this to see if I did something wrong, but I just keep getting the same answers. It's really frustrating...
