Finding Holomorphic Logarithmic Formulas for Half-Planes in Complex Analysis
12 replies · 3K views · last reply
Metric_Space
i) Find a suitable formula for log z when z lies in the half-plane K that lies above the x-axis, and
from that show log is holomorphic on K
ii) Find a suitable formula for log z when z lies in the half-plane L that lies below the x-axis, and
from that show log is holomorphic on L.
I've found a formula log Z on wikipedia but not sure how to relate it to the half plane(s).
Ok, so what's that formula for log(z)? You only have to worry about defining a continuous angle function in the half planes, right?
I think it is:
Log z: = ln r + iθ = ln | z | + iArg z.
Metric_Space said:
I think it is:
So, this is well-defined in the upper-half plane right? Can you show it's also holomorphic there?
I think it's well-defined on the upper-half plane.
Not sure how to show it's holomorphic -- should I just substitute into the definition of derivative?
I wonder if they mean the closed half-plane? The problem would be a little more challenging if they do.
Good point. But is it even true in the closed half plane? You can easily pick your line of discontinuity to lie under the x-axis, but you cannot define the logarithm of 0 in any satisfying way, can you?
You could do that. But if I were you, I would try the Cauchy-Riemann equations though. Maybe you can even use the inverse function theorem...
Good point also. Guess I was thinking closed half plane\{0}. So never mind.
Just find the partial derivatives, show they are continuous and show that the CR-equations are satisfied. This would imply holomorphicness...
you have to change co-ordinates from /9x,y) to (r,theta), this is done via the chain rule.
