Finding image position and size in a double lens system
28 replies · 8K views · last reply
Venerable R
Image: http://i.imgur.com/NMS7BUK.jpg?1
a) Find the position of the final image of the 1.0-cm-tall object.
b) Find the size of the final image of the 1.0-cm-tall object.
h = 1 cm
f1 = 5 cm
do = 4 cm
f2 = -8 cm
L = 12 cm
di = ?
1/f = 1/do + 1/di
a) di1 = 1/(1/f1 - 1/do) = 1/(1/5cm - 1/4cm) = -20 cm (virtual image through a converging lens?)
di2 = 1/(1/f2 - 1/(l - do)) = 1/(1/-8cm - 1/(12-(-2))) = -6.4 cm
This answer is not right. I would really appreciate any help with double lens systems. We're covering them now in class, and I'm very confused by optics!
Venerable R said:
a) di1 = 1/(1/f1 - 1/do) = 1/(1/5cm - 1/4cm) = -2 cm
Check the above calculation.
[EDIT: I think this might just be a typo. I also get -6.4 cm for the image distance of the second lens. Did the question state how the answer should be given? That is, are you supposed to give the answer relative to the second lens or relative to the first lens?]
Oh! It's the distance from the object! So, I added 4 cm + (12 cm - 6.4 cm) which gave me the correct answer of 9.6 cm. (Also: Yep, that was a typo!)
Thank you! :D
I have this same problem, and I also get di1 as -20cm, what am I missing? I'm having trouble determining what "do2" I should use in the second calculation? How do I get there?
-20 cm is correct for di1. The image of the first lens is treated as the object of the second lens.
I get that far but when I do the calculation, the answer is wrong. 1/f - 1/di1 = 1/di2 --> 1/-8 - 1/-20 = 1/di2 --> -5/40 - (-2/40) = 1/di2 --> 40/-3 = di2 =.13.3333cm , which is incorrect according to previous replies in this forum.
When you treat the image of the first lens as the object of the second lens, it doesn't mean that the image distance of the first lens equals the object distance for the second lens.
Draw a diagram. Locate the image of the first lens in your diagram. If that image is treated as the object of the second lens, then what should you use for the object distance for the second lens?
Can you describe in words what it means to say that the image distance of the first lens is -20 cm?
If the lens equation gives a negative image distance, then the image is virtual on the same side of the lens as the object?
Yes. So, where did you draw the image of the first lens?
Would it be to the left of the first lens?
Yes. How far to the left of the first lens?
No. How did you get that?
20 - 4 since do was already 4cm away from the first lens? Clearly I do not understand, any real explanation you could give would help..
You need to review the basic definition of "image distance of a lens (di)". It's defined to be the distance from the lens to the image (with images on the left defined as having negative image distances).
So, when you find that di1 = -20 cm, where is the image of the first lens located in relation to the first lens?
20cm left of the first lens
Yes. Good. So, next you treat this image of the first lens as the object of the second lens. What should you use for do2?
Almost. What is the sign convention for object distances?
POSITIVE 32cm! --> 1/-8 - 1/32 = 1/di2 --> -4/32 - 1/32 = 1/di2 --> di2 = 32/-5 = -6.4cm
TSny said:
That's it. Good.
Thanks for all your help. So for final position, it's relative to the original object correct?
Apparently the question asks for the distance between the image of the second lens and the object of the first lens. See post #3. Did you get an answer for that?
Two calculations are required, hi1/ho = -di/do for the first lens yields 5cm, then hi2/hi1 = - di2/di1 = 1.0 cm, correct answer
The 5 cm that you are getting represents the height of the image of the first lens? If so, OK.
The di1 should be do2. Also, note that the ratio hi2/hi1 is dimensionless, so it does not have units of cm.
About the di1 being do2, that's what I was thinking I was just unsure which notation was more accurate
If you want to make sure you are thinking correctly about the second part of the question, try answering the following questions?
(1) What is the magnification of the first lens alone?
(2) What is the magnification of the second lens alone?
(3) What is the magnification of both lenses together?
(4) How do you use the result of question (3) to determine the height of the final image?
