Finding parabola equation and only given a graph
  • Thread starter Thread starter stuffradio
    Graph Parabola
To find the equation of a parabola from a graph, start with the vertex form y = a(x + h)^2 + k, where (h, k) is the vertex. In this case, the vertex is (0, 5), leading to the equation y = ax^2 + 5. To determine the value of a, substitute known points from the graph into the equation, such as (1, 4). This method is applicable to all parabolas with a vertical axis. Understanding this approach allows for solving various parabola equations effectively.
stuffradio
The math problem I am supposed to do is, find an equation for the given graph.
There are no equations given, but here's an image for it.
I understand there is an equation like
y=ax^2+bx+c but I'm not sure how I can apply it to this graph. I know the Vertex of the Parabola is (0,5) and the line of symmetry I think it's called is x=0, but what I'm confused at is what the actual equation would be.
If anyone can give me a clue as how I can solve it, that would be great!
Put it in vertex form y = a(x + h)^2 + k where h is the x value of the vertex and k is the y value. The answer should then be y = ax^2 + 5, you can solve for a by plugging in values of x, y and then isolate a, there is a clear one (1, 4). I don't know if I can give this much information though.
Wow, I'm impressed this was answered so quickly! Thanks!
So is this a standard equation that can be used for solving all parabola's?
Especially at 1 AM!:wink:
Yes, that formula is true for all parabolas with vertical axis.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
