Finding spring constant K and compression distance
The discussion revolves around a physics problem involving the determination of the spring constant (K) and the compression distance (x) of a spring. The problem context includes concepts of conservation of momentum and energy, as well as the work-energy theorem.
  • Participants explore the use of conservation laws and question how to relate the spring force to kinetic energy. There are attempts to derive relationships between variables, such as velocity and work done by friction.
The discussion is active, with participants sharing insights and calculations. Some guidance has been offered regarding the application of conservation principles and the work-energy theorem. Multiple interpretations of the problem are being explored, particularly regarding the relationships between forces and energy.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can employ. There is a focus on ensuring that the physical quantities being compared are appropriately understood.
mpittma1
https://scontent-a-sjc.xx.fbcdn.net/hphotos-frc3/t1.0-9/10294335_1407511836191702_8633020308624670643_n.jpg
PE=.5kx^2
F=-kx
I honestly just don't know how to approach a problem where you have to find both the spring constant and the compression distance...
Ive tried employing conservation of momentum, I've tried working backwards with M1...
Im pretty sure I need to find an equation that would solve for either K or x and then use that to find the other value.
Am I on the right track?
PE=.5kx^2
F=-kx
I've tried employing conservation of momentum, I've tried working backwards with M1...
I'm pretty sure I need to find an equation that would solve for either K or x and then use that to find the other value.
Conservation of momentum and conservation of energy will each be usefully to solve relevant aspects of this problem.
Can you see how you may find the the velocity that m1 attains after the spring fully expands and before m1 gets to the friction surface?
Ya i see that;
100N = .5M1V12
so V1 = 10m/s
right?
Start with conservation of momentum to get v2 in terms of v1.
You can get v1 from conservation of energy.
mpittma1 said:
Ya i see that;
100N = .5M1V12
so V1 = 10m/s
right?
Not what I had in mind.
100 N is the maximum force exerted by the spring. (1/2) mv2 is Kinetic Energy. Those are not equal. They're totally different physical quantities.
Calculate the amount of work done by friction in bringing m1 to rest.
Ya i noticed that after i posted.
i will try that though
wf = ukmgd = (.75)(2)(9.8)(2) = 29.4 J
would impulse momentum help here?
Not really.
Are you familiar with the Work - Energy Theorem ? It tells you the relationship between work done and change in Kinetic Energy.
SammyS said:
Not really.
Ya Wnet=ΔKE
So, set 100N = ΔKE of mass 1 and find the initial velocity produced by the spring?
disregard that last post its the same mistake as the first time...
K I am getting close;
.5m1v12=wf
v1 = sqrt(29.4) = 5.422
and to find v2
v2=(m1v1/m2) = 1.36m/s
ugh finally got it!
thanks for all the help!
Where did that 29.4 value materialize from?
Its the value of the work done by friction
Wf=μk*m*g*d
Wf=μk*m*g*d
Ah. I can now see that you worked that out earlier.
