Finding stream width using angles and the law of sines
  • Thread starter Thread starter FawkesCa
8 replies · 3K views · last reply
FawkesCa
for God's sake...I NEED HELP!
AB is a line 652 feet long on one bank of a stream, and C is a point on the opposite bank. A = 53° 18', and B = 48° 36'. Find the width of the stream from C to AB.
law of sines
ive proven all variables are correct (A,B,C and a, b, c). i come up with a height of 400.74ft. the answer book says its 345.45ft.
ive done this 6 times and come up with the same answer. am i a retard or should i just not go to Clark University (its their website)
I'm also getting the same answer as you, if you let the two angles be [tex]\alpha[/tex],[tex]\beta[/tex] and the distance across the bank be d, then the width of the river is given by
[tex]w=\frac{d}{cot(\alpha)+cot(\beta)}[/tex]
and plugging in your values gives approx 400ft.
I get the same answer as the OP as well. But there is some ambiguity as to what the angles are. The "A = some angle" and "B = some angle" statements really don't make sense, since A and B are just corners of the triangle. I assumed that "A" actually meant angle CAB, and that "B" actually meant angle CBA.
Likewise, 400.739 ft., by
[tex]w = \frac{d \; \sin(\beta) \; \sin(\alpha)}{\sin(180^{\circ}-\alpha-\beta)}[/tex]
thank you, thank you, THANK YOU! i guess clark university is not the best place to try and teach yourself trigonometry. all of you help me SOOOOOOO much.
Not necessarily. Pretty much every book is going to have a few typos in it, you just need to be prepared. If you are getting a different answer and are sure of yourself, then don't be so quick to disbelieve your own work. Leave it and ask your professor or here online.
