Finding the range of x/(x^2+x+1)
navneet9431
Multiple-choice question 4 with options A) 2, B) -3, C) 1, D) 4, asking for the value of 9a + b given b ≤ x/(x^2 + x + 1) ≤ a for all real x; also partially shows question 5 with options including x^2 - 4 = 0.
Go through question number 4
Quadratic formula x = (-b ± √(b² - 4ac)) / 2a, typeset as a fraction with the square root over b squared minus 4ac.
See basically the question is asking us to find the range of the given function x/(x^2+x+1).
So,I began solving it this way...
Handwritten derivation: let the range be y for some values of x. Then y = x/(x^2+x+1), which gives y x^2 + (y-1)x + y = 0.
I am stuck at this step.
I asked my friend for a hint and he told me to apply the condition that Determinant(D)>=0.
But,I am unable to understand why D>=0?
I will be thankful for help!
  • Multiple-choice question 4 with options A) 2, B) -3, C) 1, D) 4, asking for the value of 9a + b given b ≤ x/(x^2 + x + 1) ≤ a for all real x; also partially shows question 5 with options including x^2 - 4 = 0.
  • Quadratic formula x = (-b ± √(b² - 4ac)) / 2a, typeset as a fraction with the square root over b squared minus 4ac.
  • Handwritten derivation: let the range be y for some values of x. Then y = x/(x^2+x+1), which gives y x^2 + (y-1)x + y = 0.
The function that is bounded by a and b is ##f(x) = \frac x {x^2 + x + 1}##. For large x or very negative x, f(x) approaches zero. The function is continuous everywhere, and has both a maximum and minumum value. You have posted this question in the Precalc section, but the problem is one that can be solved using techniques from calculus, to find the two extreme points.
BTW, in your thread title, you described this as a problem about a polynomial equation, which it isn't. I've edited your title so that it is about a rational inequality.
