Finding vector w from 5u + 4v with given components
  • Thread starter Thread starter sarabee
    Precalc Vectors
11 replies · 3K views · last reply
sarabee
If u=-7i-3j and v=-4i+4j, find w=5u+4v.
2. I'm not sure which equation to use? Test is tomorrow so fast help would be great!
: So my teacher gave us the answer key and it reads: -51i+j and i am not sure how to get that?? Please help![/B]
Thanks! Just solved & it makes perfect sense.
While I have you here, i might as well ask another question:
Find the magnitude and direction angle of v=2i-2j. Round direction angle to nearest degree.
Answer is llvll=2radical2 and theta=315deg
not sure how to get that!
jedishrfu said:
Try plugging in the the u and v vectors into the w equation and regroup adding like terms ie the i terms and the j terms.
I'm not sure how to tag you but.. I'm just going to try this
If you draw the vector on graph paper you'll see it makes a triangle with the x-axis.
so how would you determine the angle between the vector and the x-axis using trig
for the magnitude, you're familiar with the pythagorean theorem right?
so...would the point just be <2,-2> then? and i just don't understand at all how to graph a triangle given only one point
and yes i am familiar with the pythag theorem
jedishrfu said:
You have a vector so place its tail at 0,0 and now you have a triangle
http://imgur.com/OhURuK8
So this is the triangle i have now
http://imgur.com/OhURuK8 if you can't see that image. what do i do next?
Review your notes on vectors this is a very simple problem and I've given you enough hints. You see the triangle and you must know trig, the hypotenuse length is the magnitude of the vector.
Thanks for all your help, I have it figured out for the most part.
When i am using trig to solve for a direction angle, which one am i solving for? the one that is nearest to (0,0)? or the other one?
http://imgur.com/PwVyw6S
This problem is less about what equation to use, but more about 1)how two add two vectors, and 2) how to multiply a vector by a scalar.
If you spend your time trying to memorize equations without any understanding, you won't do well on a test.
