Finding velocity relations between three particles
11 replies · 2K views · last reply
Jahnavi
Handwritten problem with a diagram of three velocity vectors V1, V2 and V3 in the x-y plane, V1 along the x-axis, V2 along the y-axis and V3 at 45 degrees, followed by four multiple-choice options for their relation.
[/B]
Apologies for a bit hazy picture .Let the three particles be in a line after time 't' . If the inclined line (path of v) from the origin is perpendicular to the hypotenuse then we could write vt= v1cos45°t = v2cos45°t . But then it also means v1 = v2 .
Could someone help me with the problem .
  • Handwritten problem with a diagram of three velocity vectors V1, V2 and V3 in the x-y plane, V1 along the x-axis, V2 along the y-axis and V3 at 45 degrees, followed by four multiple-choice options for their relation.
So you have three particles released from the origin simultaneously. One with a velocity v1 along the x axis, a second with velocity v2 along the y-axis and a third with a velocity v along the 45 degree diagonal in between.
We are not explicitly told that the particles are released from the origin simultaneously. That is an assumption on my part. I make it because the problem is pointless otherwise. All three velocities could be arbitrary.
We are told that the particles are eventually collinear at some time t and asked to find a relation between v1, v2 and v. I do not see a statement that the line connecting the three particles need be perpendicular to the path of the diagonally moving particle.
Question for you: If the particles are collinear at some time t (t not equal to 0), are they collinear at all other times t'?
[The point of asking this question is to allow us to dispense with velocities and reason directly about positions instead]
Since this is posed as a multiple choice question, an attractive approach is to start by eliminating the obviously incorrect alternatives.
Sorry . I can't think of a condition which either makes the particles collinear or not .
OK. Let's ask a simpler set of questions:
1. What are the positions of the three particles at time t?
2. What are the positions of the three particles at time t/2?
By position you mean coordinates of the particles ?
Yes.
Let us call particle with velocity v1 , A . Particle with velocity v , B .Particle with velocity v2 , C .
A at time t = (v1t,0)
B at time t = (vt/√2,vt/√2)
C at time t = (0,v2t)
A is correct for time t.
B is correct for time t.
C is correct for time t.
You have not answered for time t/2.
Edit: confused myself at first on B. You were correct.
A at time t/2= (v1t/2,0)
B at time t = (vt/2√2,vt/2√2)
C at time t = (0,v2t/2)
Now, a principle of analytic geometry (or linear algebra) is that if you take a geometric figure, multiply all of the coordinates of its vertices by a single fixed multiple and look at the resulting geometric figure, the two figures will be "similar". In particular, if you have three points on a line and multiply their coordinates by the same multiple, you'll have three points on a different, parallel line.
From this you should be able to conclude that if A, B and C are collinear at time t, they are collinear at time t/2 and, in fact, at all times.
Thanks . I get the right answer :smile:
Dimensionally all four options look okay . How do we find the obvious incorrect alternatives ?
Choice 1: v = v1 + v2
If the X axis ball were at (1,0) and the Y axis ball were at (0,1) that would put the diagonal ball at (1,1). That's not a line and never will be a line.
Choice 2: v = ##\sqrt{v_1 v_2}##
That means that v is the geometric mean of v1 and v2. So if v1=1 and v2=1 then v=1. But that means that (1,0), (0,1) and (##\frac{\sqrt{2}}{2},\frac{\sqrt{2}}{2}##) would have to be all on the same line. But no, they're obviously on the same circle instead.
That sort of thing.
